torsion/shackle lift
Old Oct 19, 2011 | 05:24 AM
  #121
srch4me's Avatar
srch4me
well theres a difference between broke and worn out. your supposed to replace shocks like every 40,000 miles or something...
Old Oct 21, 2011 | 12:32 PM
  #122
MoparMan1991's Avatar
MoparMan1991
If your shocks were worn out you'd definitely know it.
Old Oct 26, 2011 | 10:32 PM
  #123
thenyscrod's Avatar
thenyscrod
Ok so I am doing the shackle torsion lift tomorrow.
As per what ROCKSURFER said to buy, I bought the 2" lowering shackle for an 89 Chevy C1500. They look so long.......
And mtndewnut, where did your pics go ?
Old Oct 27, 2011 | 01:04 AM
  #124
MoparMan1991
Okay. NOW, if you can re use the old bolts then do it! if not then get grade 8 everything with some thread lock (Loc-Tite). You will have to drop your spare and remove your trailer hitch if you have one on so you can access the drivers side shackle. Make sure to lift your rig up and put jacks on the frame so you can take the stress off the suspension. You may need to use some force to get the old bolts out. I had to twist the bolt and hit the small end to get the bolts to twist out. Don't forget the washers to shim the extra space out.
Old Oct 28, 2011 | 07:31 PM
  #125
thenyscrod's Avatar
thenyscrod
Mission Completed !!!!
I like the new look...
Was not that hard with a lift.....
took about 30-35 min.
Old Oct 29, 2011 | 04:46 AM
  #126
MoparMan1991
Lucky! It took me about 4 hours total, but like I said my bolts were dry so I had to take some time getting them out.
Old Nov 16, 2011 | 12:56 AM
  #127
Lynaugh's Avatar
Lynaugh
So if I get Superior Automotive lowering shackles (Part # 13-4100) and crank the torsion bars 8 full rotations I will get enough clearance for 32" tires without rubbing or do I have to get a body lift as well?
Old Nov 16, 2011 | 11:14 AM
  #128
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
32" will fit fine with that, 33"s will not
Old Nov 17, 2011 | 04:20 PM
  #129
Lynaugh's Avatar
Lynaugh
Awesome thanks a lot.
Old Nov 17, 2011 | 04:45 PM
  #130
jmess's Avatar
jmess
I have 33/10.5x15 with my t/s lift and the only issue is in full turn on the frame.
