torsion/shackle lift
Old May 24, 2012 | 10:45 AM
  #151
jmess's Avatar
jmess
Originally Posted by shrpshtr325
will eat up cv joints in the front axle
why is that?
Old May 24, 2012 | 09:40 PM
  #152
adukart's Avatar
adukart
Cause they aren't built strong enough. It is like plowing through mud or sand all the time, it is a lot of rotational resistance on them from the extra weight of the tire and increased diameter.
Old May 24, 2012 | 11:54 PM
  #153
jmess's Avatar
jmess
Ahh. Thank you. Get it now. Pretty glad someone brought this up. I planned on going with 35s after my 33s were done. Assumed everything could handle it. Replacing my cv axles was a nightmare the first time too. Don't wanna have to do that again.
Old May 25, 2012 | 07:04 PM
  #154
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
srch you are correct, chalk that one up to too much booze and lets move on
anything over 31inch tires will prematurely wear out the c/v joints prematurely, 33s will not have too noticeable an effect, but itwill still be there, even 31s will wear them out faster than the 29s which came on the 15inch rims would. As stated above this is because there is alot more rotational mass, make it much harder to keep the tires in place and under control, this issue also affects the steering components in the front.
