TPS issues
Old Aug 24, 2017 | 06:25 PM
rnrphoto98's Avatar
rnrphoto98
Default TPS issues
Hi all
I have an 03 Durango with the 4.7. A few months ago I started to get the wandering Rpm's so I replaced the TPS. All was great till last week when it started acting up again rpms going up and down again. Then yesterday, I put on the cruise control and the engine just died, had to pull to side of hwy, tried to start it, it would rev up and just die. Finally I turned the key off waited a min and it started up. I thought it was because of the cruise control at first. 5 min it later without cruise on it died again. Same thing. It did that twice. Check engine light came on I got a 0068 and 0121 code. So I replaced the TPS again and it is running fine.
So my question is, is it normal for a TPS to go bad so fast? Is there anything else that would make it go out?
It seems like there are a lot of things that function by working together with other sensors and the main computer, I just don't know what would affect the TPS.
Thanks
Rob
Old Aug 26, 2017 | 03:16 PM
TPS is just a variable resistor. It gets a 5 volt signal from the PCM, and the return voltage is less..... so, in theory, they should last a good long time..... Thats for factory parts though. The super-cheap-china-made-crap..... you are lucky if it works at all. So, for critical sensors on your truck, go to the dealer for replacement parts. Sure, they cost more, but, chances are good, you will only have to replace it once.
Welcome to DF!
