crankshaft sensor
Old Jun 18, 2018 | 04:20 PM
duckytwizzler57's Avatar
duckytwizzler57
Default crankshaft sensor
i replaced my crankshaft position sensor and the code popped right back up i have a 2003 dodge durango 4.7l v8
Old Jun 21, 2018 | 06:24 PM
What code?
Old Jun 21, 2018 | 06:45 PM
duckytwizzler57
p0335 p0315
Old Jun 23, 2018 | 12:13 PM
Check all the wiring associated with the crank sensor. Also, what brand sensor did you buy?
Old Jun 24, 2018 | 09:37 PM
duckytwizzler57
I don't know the brand but I am having a hard time finding where the wires go to I can find the crank shaft but am having a hard time following it up to the other side. I brought it to a garage and they only spiced it where I can see it waste of $80 for a job I could have done
Old Jun 25, 2018 | 05:27 PM
Pretty much. Think I would take a good hard look at their splice though, if you are still seeing the same codes.
Old Jun 25, 2018 | 05:41 PM
duckytwizzler57
thank you i will do that now it cranks with no start and my ignition coil #1 has no spark
Old Sep 6, 2018 | 10:48 AM
Jason Marshall's Avatar
Jason Marshall
where did you get the sensor and is it OEM because I went through 2 of them that were after market that didn't work. I suggest getting one from NAPA part # ECH CSS620 that one worked great for me although I did have to sand the plastic that goes in the block for it to fit.
