What size tension band clamps for heater hose & heater core?
Old Feb 2, 2019 | 04:35 PM
Rob94hawk's Avatar
Rob94hawk
Default What size tension band clamps for heater hose & heater core?
The worm gear hose clamps I'm using after I replaced the heater core are constantly backing out, dripping antifreeze on coil #3 and causing a short (I lost two clamps during the rebuild)
I bought these but they are too small:
Amazon Amazon
What is the right size? Thanks.
Old Feb 2, 2019 | 06:49 PM
Dodgevity's Avatar
Dodgevity
Probably these... https://www.ebay.com/p/Mopar-OEM-5-8....c100854.m4779
In case the link expires, it's Mopar part 6502017
24x15 constant tension clamps for 5/8" hose.
Old Feb 2, 2019 | 09:25 PM
Rob94hawk's Avatar
Rob94hawk
Thanks for the part #! Don't know what I'm going to do with 15 clamps though.
Old Feb 3, 2019 | 09:02 AM
Dodgevity's Avatar
Dodgevity
Google it and buy fewer. Personally, I'd just visit a junkyard. You should find plenty across many vehicles.
Old Feb 3, 2019 | 09:37 AM
They should have them on the shelf at your local parts store as well.
Old Feb 3, 2019 | 11:57 AM
Rob94hawk's Avatar
Rob94hawk
They didn't. That was the first thing I tried.
I just bought the 15. I could replace the old ones and use them to secure my crankcase vent hoses which are loose.
Old Feb 3, 2019 | 12:06 PM
TheCableGuy's Avatar
TheCableGuy
Might be a dumb question but why not just get those screw-hose clamps? I use them on everything and super cheap. Along with easier to replace/remove.
Old Feb 3, 2019 | 01:03 PM
Less hazardous to your health as well.
Old Feb 3, 2019 | 02:51 PM
Dodgevity's Avatar
Dodgevity
Screw clamps can cause issues. They're okay when used on metal pipes but never use them with plastic, such as the radiator top and bottom hoses on most cars. The spring clamps will expand and contract with heat expansion... a screw clamp won't. Eventually the screw clamp will cause the plastic to crack or disintegrate. I've personally experienced that on a few cars, till I learned.
Old Feb 3, 2019 | 03:20 PM
TheCableGuy
That makes sense to me, my apologies. The only reason I ask is because Iv used them for practically everything on my vehicles. On my 11’ GM and now this 01 Durango. Haven’t had an issue yet.. but you are right. Something can and will eventually happen.
