2000 Durango 4.7l Engine issue
Old Jul 23, 2019 | 06:03 PM
sporta's Avatar
sporta
Default 2000 Durango 4.7l Engine issue
Hey all...
Well the '00 Durango acted up again this morning...
Roommate was driving wife to work and it seems to "stutter" while at freeway speeds, then bucked a couple times and shut off. Luckily they were at her off ramp and coasted to the bottom...Called AAA and had the Durango towed home. First thing I did was check for codes...P0420 was still showing (just got replacement Upstream o2 sensor and had been trying to get the driveway cleared from the '00 5.9l) and nothing else. Had roommate crank it over a couple times...horrendous sound from extreme front of engine...had him immediately stop...got in and watched the gauges closely as I bumped the starter...nothing showed on the oil pressure and the tach barely moved...I'm thinking possible oil pump or ? Remember this engine has just had heads, cams, followers, timing chain/guides/tensioners replaced...anyone got a suggestion on where to begin? ? ?
Old Jul 25, 2019 | 09:56 AM
Recheck the timing stuff. Something may have slipped out of place.
Old Jul 25, 2019 | 11:28 AM
sporta's Avatar
sporta
Would that cause the shutdown as dramatically as is happened, or would it have shown more symptoms? We were initially leaning towards the oil pump but are certainly open to suggestions.
Old Jul 25, 2019 | 12:06 PM
If it slips bad enough, yeah, the engine will stop running. I think you can just pull some covers, and see what you need to. I think......
Old Jul 26, 2019 | 06:42 PM
sporta's Avatar
sporta
Found the cause of the issue...passenger side (right) chain tensioner exploded and snapped the timing chain guide... the plastic guide over the metal is just GONE....no clue where it ended up. Dodging thunderstorms...hoping to look in the pan with my bore scope tomorrow.
Old Jul 26, 2019 | 07:56 PM
That's likely where you will find it.......
Old Jul 27, 2019 | 01:45 PM
Dodgevity's Avatar
Dodgevity
...or ground up in the oil filter. Did you change the tensioner when you did all the work?
Old Jul 27, 2019 | 02:38 PM
sporta's Avatar
sporta
To clarify, you mean the L and R units that you have to pull the "hand grenade" pin to release the cylinder that presses up to the guides, then yes. I have changed them 2x to be safe.
