P1762.. Governor pressure solenoid
Old Oct 16, 2019 | 11:37 AM
Stevedillon's Avatar
Stevedillon
Default P1762.. Governor pressure solenoid
Alright who's had to mess with this code. On the 46re transmission. 2001 dodge durango slt plus 5.9 4x4. I dropped the pan replaced the governor pressure solenoid along with new filter an new atf 4 reset computer and the dodge still doesnt want to to come out of first gear. Wants to rev up to 3 or 4k rpm i let off the gas and somewhere around 1500 and 2k rpm it will shift up to next the next gear. Where do i go from here?
Old Oct 17, 2019 | 11:26 AM
DodgeGeekr's Avatar
DodgeGeekr
Did you replace the solenoid with an oem part? Also has the trans ever had bands tightened? Also what is your current milage on ur d.
Old Oct 17, 2019 | 01:00 PM
Stevedillon
Default Oem yes
Yes i replaced it with oem parts. Solenoid i put innwas a little bigger than the one that. And out. But same part. To my knowledge the bands have not been tightened. The transmission was replaced in reno nv two and a half years ago. Current milage is 201000.
Old Oct 17, 2019 | 01:02 PM
Stevedillon
It will shift up but only if i let it rev to 4k or 5k then let it drop sown to around 2 to 1500 then it shifts. I didnt replace the transducer... Pretty sure i blew it on that. Should hage replaced everything in there while i had it opened up but the part store here did nit hage the transducer on hand.
Old Oct 17, 2019 | 06:17 PM
Stevedillon
Ritenow it seems to be shifting normal after pushing it through town then a brief stop to pick kids up from school turned it off started it an ot ran normal shifted normal all the way back.... What could the issue be a short??? Help
Old Oct 17, 2019 | 07:26 PM
Probably pressure sensor. If it stays fixed, don't worry about it. If it starts doing it again, replace the pressure sensor, and adjust the bands while you are in there. (and install a drain plug? )
Old Oct 17, 2019 | 07:54 PM
Stevedillon
Defiantly hoping it stays working rite. Trans is only 2 years old. But if it happens again ill be into it again. And yes Going to get a new pan with drain plug this no drain plug crap is no good.
Old Oct 24, 2019 | 11:58 AM
Stevedillon
Default Well.... Problems back.
Back again with the not wanting to shift issue.
Old Oct 24, 2019 | 06:33 PM
Time to replace that sensor?
Old Oct 24, 2019 | 08:29 PM
Stevedillon
Default Yeaaaaa
Thinking so.
