What brand IAC motor? Did you clean the throttle body really well? They do tend to collect a lot of crap in the IAC well. Are you still getting the IAC code?
Brand is BWD. I had a very hard time finding a genuine Mopar part. Looks to be discontinued and I havent found any extra stock. Throttle body is clean as a whistle I thoroughly and properly cleaned it over a week ago and changed TB gasket. The IAC is clean as a whistle too. Yes I am still getting IAC code after all this. Doesnt my high reading of resistance in the harness mean its either wiring or PCM?
Check rock auto for the IAC, if nothing else, you should be able to get a mopar part number, and you can search on that. Worst case, see if you can find a standard motor products unit. They tend to be at least a bit better quality.
