Dies while in drive.
Old Aug 18, 2020 | 08:12 PM
Christy Holloway's Avatar
Christy Holloway
Default Dies while in drive.
1999 Durango never had a problem out of this truck. But when I got it the check engine light was on. It's still on but never a problem. But today my dad was driving and it died in drive and anytime you try to take off in drive or when you press the gas it dies. But you can put it in second and it will do fine. Auto zone said it could be a sensor basically a vacuum leak. I need some good advise this is my only ride and can't afford another one I'm a single mom who can't work right now due to the virus going on. So anybody with any thoughts I'm all ears. Thanks
Old Aug 18, 2020 | 09:28 PM
Packwood Digital's Avatar
Packwood Digital
have you ever had the check engine light checked to see which code?
is it an automatic transmission?
Old Aug 18, 2020 | 10:07 PM
Christy Holloway
No I haven't got it checked cause never had a problem out of it no misfires hesitation nothing. Yeah it's a 5.2 no 4x4
Old Aug 18, 2020 | 10:34 PM
Packwood Digital
At the risk of sounding over simplistic you need to check the code ASAP they sell scanners for like $30 at harbor freight (of cost is an issue just return it they are pretty no questions asked about stuff)
it very well could be that whatever’s giving you the code was a minor problem until it got worse and now it’s dead as a result.
when you say it works in 2nd gear are you just putting the selector in the “2” on the gearbox? And then starting it?
if your driving it in “2” and then put it into 1 or into D does it just die right away?
”usually” only working in 2nd gear is a sign of the transmission being in what’s called “limp mode” that may or may not be the case here
transmission issues “usually” don’t result in the car just dying when touching the gas.
also, does the whole car shut off as in electronics and all? (Does the radio turn off and headlights turn off) or does it just putt putt out as if it’s out of gas?
Old Aug 19, 2020 | 06:16 AM
ol' grouch's Avatar
ol' grouch
You need to see what code is stored in the computer. One nice thing about Chrysler products is you don't need a reader to check the codes. Do what is called the key dance. Turn the ignition on, off, on, off and then leave it on the third time. Do not bump the starter. This tells the computer to go into self test mode. If you engage the starter, you'll have to start over. The codes will show up in the odometer display. On older (1995 and earlier) cars the check engine light will flash. OBD II, which is what you have shows the code as numbers. Once you have a code(s), post them here and we can go from that.
Old Aug 19, 2020 | 10:12 AM
Not sure that works on the 98 and newer trucks..... worth a shot though.
Old Aug 19, 2020 | 01:55 PM
Mawgman1's Avatar
Mawgman1
Can confirm it works on the newer trucks, I have an 03 'Rango and they key dance works wonders...
Old Aug 21, 2020 | 01:56 PM
bryce_crowder's Avatar
bryce_crowder
I had a similar issue, but mine would idle rough and then die, if scanning for a code doesn't get you anywhere, look into a throttle position sensor. They're like $20-$40 and EXTREMELY easy to replace (two screws and it's right on top of the engine, literally just take the old one off and put the new one on). I've had no issues with dying or rough idle since.
Old Aug 25, 2020 | 12:32 PM
Packwood Digital
Scanning for codes doesn’t get you anywhere? That’s a pretty relative statement.
Old Aug 25, 2020 | 12:47 PM
bryce_crowder
Because that issue doesn't trip the check engine light. The light could be on for a different reason that wouldn't point to that.
