Durango shuts off when I hit a bump or rough road.
Old Sep 11, 2020 | 01:43 PM
Aesocbar33's Avatar
Aesocbar33
Default Durango shuts off when I hit a bump or rough road.
I have a 99 Durango 5.9 that I just had completely overhauled. Runs like a champ but, if I hit a bump the truck gauges spike and I lose power. If I time it right I can punch the gas and it won’t shut off. I’d like to know where to start to find the issue. I know it has to be electrical. I’m going up north in a few weeks and would love to get this fixed before then. Also truck starts right back up when it shuts off.
Old Sep 11, 2020 | 02:26 PM
Do all the lights come on in the cluster as well?
Old Sep 11, 2020 | 06:09 PM
Aesocbar33's Avatar
Aesocbar33
Yes they do!
Old Sep 11, 2020 | 06:29 PM
Loose connection somewhere. You lose power for a bit, and when it comes back, the cluster goes thru its test. Check the main battery connections, from the battery to the PDC, and most certainly to ground.
Old Sep 11, 2020 | 06:31 PM
Aesocbar33's Avatar
Aesocbar33
That’s the only thing that wasn’t replaced was the ground and now that I look at it it’s super dry and old. 👍🏽
Old Sep 11, 2020 | 06:36 PM
Aesocbar33's Avatar
Aesocbar33
Now that I look at it the ground cable was the only cable that wasn’t replaced on the battery connections. It’s pretty dry and old definitely could be the culprit! Thanks!
Old Sep 11, 2020 | 06:50 PM
Aesocbar33's Avatar
Aesocbar33
Never mind here’s the culprit!
Old Sep 11, 2020 | 08:09 PM
That will most certainly do it.
