Starter cranks 2-3x then stops.
Old Jan 17, 2024 | 07:59 AM
Originally Posted by Shawn King
Thats exactly what I’ve been trying to explain that I did. No it still won’t start. Then it just cranks. Whatever it is also kills other systems as well. Like maybe fuel pump. I have not confirmed this yet.
Ok, I read that you had the key in the crank position....
Need to find out just where power is dropping out. Those circuits are all fused, no circuit breakers.... so its probably just a bad connection somewhere. "Where" becomes the million dollar question.
Verify that you still see power from ASD relay, and Fuel pump relay. Also, that you still getting power TO those relays.
Old Jan 17, 2024 | 11:01 AM
Shawn King's Avatar
Shawn King
Yes I agree. Thank you. This will have to wait until some slightly warmer weather. It’s 10° and windy right now.
I’m thinking it could be a bad ground or connection because of it. Seems like it acts up more when it’s cold.
Old Jan 17, 2024 | 02:00 PM
Oh c'mon now. He doesn't just LOVE playin' outside in the arctic weather???? Oh, yeah, that's right, nobody.....
Old Jan 27, 2024 | 06:22 AM
Dodgevity's Avatar
Dodgevity
I know you think you've ruled out the starter but I'd at least pull it off the truck and have a look at the copper contacts in the solenoid. When they wear, the gap is so tiny, it is affected by temps. Won't cost u but a bit of time and if you want to change the contacts, it's less than 20 bucks. Pics in my thread below.
https://dodgeforum.com/forum/2nd-gen...atibility.html
