2000 Durango 4.7L with "gremlins"
Hey all, my 2000 Durango had something really strange happen today. The turn signals are acting up. When you go to activate the signals (either L or R) and push the lever to the stops where it "locks" in place for the turn, the lights will flash for a few seconds then nothing. If you only partially press the lever in the direction of intended turn and HOLD it, they will flash just fine.....Sounds to me like a bad switch (or maybe dirty contacts) anyone have a suggestion on what could cause this?
Side note, as we were driving my lovely wife said maybe check the fuse, but that is not what my deaf **** heard....I thought she said maybe check the BLINKER FLUID...the incredulous look on my face as i turned to her and asked WTF did you just say? Because I thought you said blinker fluid....nope she said fuse....yep folks , sometimes I am thick as a brick lol
Steve
Steve
I would have liked to have seen the look on HER face when you mentioned blinker fluid.
That had to have been stellar.
My first thought would have been the flasher module, but, if it works fine in the 'lane change' position.... That probably isn't it. Do the hazards work properly?
That had to have been stellar.My first thought would have been the flasher module, but, if it works fine in the 'lane change' position.... That probably isn't it. Do the hazards work properly?
Ok. Back to the drawing board here. Took Red on an extended trip over the weekend. Turn signals were acting up all the time. Hazards when engaged seem to function correctly. The lane change position, will function 3 or 4 flashes then stop. Then it degraded to 1 or 2 flashes then stop. If lever is put in full turn mode, you might get 3 flashes or 1 then nothing. As the weekend moved on it seemed to get worse.
On a side note dealing with Gremlins, we shut Red off and had the ac on with fan blowing high when we stopped for a drink. Upon restart, the dash fans would NOT blow at any position. Shut off car, fire it back up...nada. Do it again and the fans worked in all positions.
Any suggestions on where to start looking for the gremlins? Dirty contact on the turn signal switch? Same on the fan or am I looking at something bigger?
Thanks in advance,
Steve
Thanks in advance,
Steve
Think I would have a look at the connection at the ignition switch. Neither of those circuits are hot when the ignition is off.... Both are when ignition is on. Do you actually have a turn signal flasher? Or does that go thru the central timer module??
Thanks
Steve
Trending Topics
One of the gremlins has been truly slain! The turn signal gremlin was caused by the flasher unit! What a PITA to get to! I hope the engineers who decided where to place them stubs their little toe nightly! Luckily, baby red had one that functioned and the total cost was $0.00. That's a win in my book for sure. Now to figure out the fan control. It hasn't happened again (knock on simulated wood grain) so I'll just keep an eye on it.
Steve
Steve
