4.7 cooling system issues im having
Old Jun 21, 2021 | 01:20 AM
Tanerex's Avatar
Tanerex
Default 4.7 cooling system issues im having
okay so to start off i just replaced my head gaskets and had the entire engine apart so there is all kinds of potential for air to be trapped in my cooling system and second my bleeder valve is stripped ( i am doing the martinbuilt solution to this in a week and making my own bleeder valve) but entil then i have tried bleeding it from the pressure cap on the upper hose right next to the bleeder valve, i turned it on, took the cap off, turned the heater on full blast and let it run for about an hour maybe slightly longer while i sat there and monitored it and topped it off now and then and the bubbles (big bubbles) seemed to just keep coming, infact there were like 10 instances where the coolant exploded out of it ( i assume was just a big bubble) and then would settle back down and i would add alittle more coolant and i was gentle about it to try and not add more air bubbles with sloppy pouring. any solutions or should i just wait until i make my new bleeder valve and use it?
also to note before my head gasket blew i had just the slightest bit of exhaust fumes leaking into my coolant but i drove it for like 3 months and it didnt effect it at all.
PS. its a 4.7
Old Jun 21, 2021 | 06:40 PM
Tanerex's Avatar
Tanerex
Also to note if i haven't already, when i was driving it, once it got up to temp the pressure plunge on the cap broke and let steam and coolant out of the cap, maybe a bad cap or hose combo? I did replace the hose and cap 7 months ago before i replaced the head gaskets.
Old Jun 22, 2021 | 09:47 AM
Do you still have a head gasket leak? Is the cooling system building pressure as soon as you start it?
Old Jun 22, 2021 | 07:32 PM
Tanerex's Avatar
Tanerex
Head gasket leak is gone, i got it to stop spewing coolant at temp but it does still get a bit over regular temp I'll get. Ack to you when i get it cooled off and i top the coolant off cause it seems like it has a lack of coolant rn
Old Jun 26, 2021 | 04:46 PM
sporta's Avatar
sporta
Have you tried having the nose of the vehicle elevated when trying to burp it? Example would be to park on an incline with the rear of the vehicle downhill...might help get the bubbles out. Had a Cherokee that the only way to get air out of the cooling system was to go nose down because the sealed reservoir was on the firewall.
Steve
Old Jun 27, 2021 | 04:40 AM
Dodgevity's Avatar
Dodgevity
Agreed.
I’ve never used my bleeder valve because it’s frozen solid and bends every tool I’ve tried to use. I leave the cap off and run with front end highly elevated when bleeding. Rear elevated when draining.
Keeping heater on hot does nothing for these trucks. They don’t have heater valves, so coolant is always circulating thru core.
If bleeder valve is stripped, is it not leaking or sucking air? Check fan clutch or radiator for blockage.
