03 stuck in neutral
Old Jul 20, 2021 | 12:48 AM
Daleboeski's Avatar
Daleboeski
Default 03 stuck in neutral
I was driving down the Rd and without warning no slipping or any weird noises the truck bucked and it feels like it's in neutral in all gears except park
Old Jul 20, 2021 | 07:10 AM
Daleboeski's Avatar
Daleboeski
It's the 4.7 engine forgot that in original post
Old Jul 20, 2021 | 07:23 AM
2 or 4 wheel drive?
Old Jul 20, 2021 | 08:17 AM
Daleboeski's Avatar
Daleboeski
2 or 4 wheel drive?
4 wheel
Old Jul 20, 2021 | 02:18 PM
Is the t-case in neutral? With the truck in gear, can you push it? What about in park?
Old Jul 20, 2021 | 03:51 PM
Daleboeski's Avatar
Daleboeski
I can push it in gear but not park and I worked the switch for the transfer case you can hear it work under the truck and the neutral light doesn't come on it seems to work properly
Old Jul 21, 2021 | 07:28 AM
Sounds like the trans went belly up.
Which engine/trans ya got?
Old Jul 21, 2021 | 03:33 PM
4.7 Jonesin's Avatar
4.7 Jonesin
Same thing happened to my 01 SLT yesterday.
Really frustrating after restoring the engine..
It appears to be the tranission pump.Although I haven't fully check d it out yet.
Would be nice if it was a cable.But I Doubt it
Old Jul 21, 2021 | 08:22 PM
4.7 Jonesin
Default Why No P Codes when this happens?
​​​​​​KInd of strange no P - codes come up when this happens.
​​​​​​Perhaps no codes is the code?
so what is your plan ?
Old Jul 22, 2021 | 10:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
The sound you are hearing, Does it sound the truck is sucking air? Most of the time of on a RFE transmission, If the seal isn't installed correctly the filter will drop down and cause you to loose all forward and reverse gear. I would drop the pan and inspect. If you can post pictures so we can see what's going on. Also check the side plate on the valve body too. If the plate is bent that will cause you to loose 3rd and 4th gears.
