Back up, & rear brake light problem.
Old Jul 23, 2021 | 06:45 AM
willie killagain's Avatar
willie killagain
Default Back up, & rear brake light problem.
Hi Everyone ! I've had no back up lights for some time on My 00, 5.9 RT. But now on the rear passenger brake light is not working.. The bulbs are not burnt the fuse's are not blown. Once again I and Thankful & Grateful for thoughts and advice from My Mopar Family concerning this issue
Old Jul 23, 2021 | 07:06 AM
With the truck in reverse, are you getting power to the backup lights? Might be as simply as replacing the switch on the trans.
Old Jul 24, 2021 | 10:54 PM
willie killagain
Hey You, Thanks for the reply Hopefully in the next day or so Ill get a little time to crawl under to replace it .Ill let You know after that. Thanks Willie.
Old Jul 25, 2021 | 01:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
Try switch the lens on the rear. You could have a bad circuit board in the lens assy.
Old Aug 2, 2021 | 02:10 AM
willie killagain
Hi everyone, I replaced the switch on the Trans, replaced the sensor on the differential, the break light switch under the steering column. And here's where it stands. I now have back up lights . But with break lights, only one is working . Now it's the drivers side break light is working and the passenger side is not just, the opposite to what is was before
Old Aug 3, 2021 | 07:58 AM
jims's Avatar
jims
Check your lamp sockets being you could of just switched them side to side while working on it... take note..the left one has a surface broken off at compared to the opposite with the nips..
Funnier things you know
Bulb Holder
Old Aug 4, 2021 | 02:05 PM
willie killagain
Thank You for the idea and also the pics showing the differences .When I get some time in the next couple days I will check it out, and You are right funnier things have happened the funny thing is , is its not always so funny at the time! Thanks
Old Aug 7, 2021 | 07:47 AM
willie killagain
Hi Everyone ! Last night I switched the tail lights and this time it showed that one of the circuit boards is bad. So I'm going to replace the board this morning .Hopefully problem will be solved ,I can then do a final update to this problem and then close out the post and then move on to the next issue which has to do with the cooling system.
Old Aug 8, 2021 | 06:33 AM
willie killagain
Default Let Your light Shine !
Went to pick & pull as planned got the new tail light assembly and a few other small fixes I've been meaning to take care of .I really enjoy going there. And now for the 1st time in a long time All My lighting is working properly all the way around. So now it will be on to changing out the trans fluid Some of these maintenance issues I want to come up to date on Get on top of them before they get on top of Me So now We can close out this thread I guess. You Guys have been great with Your shared experience's and trouble shooting tips. And ideas Thank You very much, Thanks also to everyone who took the time to read this Thread as well
