one fog light out
Old Nov 28, 2021 | 03:02 PM
Tshane72's Avatar
Tshane72
Default one fog light out
Noticed a few times on my 2002 Durango, the passenger side fog light would not work, I would just reach under and twist the wire harness going to it to make sure it was properly seated into the back of the fog light and it would come back on and stay on for a couple of weeks, then it would do it again. Well now today it won't come on at all now. Tried a new bulb and still no dice. The driver's side fog works just fine along with the running lights and everything...so it can't be the fuse right? Something up with the wiring going into that fog light? Any suggestions would be greatly appreciated. Thanks in advance!
Old Nov 28, 2021 | 04:10 PM
Dodgevity's Avatar
Dodgevity
Put a meter on the plug. See if it's live there.
Old Nov 28, 2021 | 09:08 PM
Calamity Coyote's Avatar
Calamity Coyote
More than likely, the connection was bad and arching. Each time you would mess with it, it would spark the connection for a bit until it got cold again. Over time, this probably burnt out the connection. I bet if you look at the plug, you will see it is toasty. It is possible to be saved. Just depends on how bad it is. I've cleaned them out with electronics cleaner and a wire brush before and mixed in some dielectric grease and they were good to go again. Just depends on how bad. Hopefully you won't have to actually replace it.
Old Nov 29, 2021 | 06:37 PM
Tshane72's Avatar
Tshane72
Thanks guys for the replies, I don't have a meter or anything to test the connection, I'll probably have to take it somewhere for that. though I think before I do that I'll go Calamity's Coyote's route and try cleaning out the connection. I know I have some of that grease lying around as well. I mean, the truck is almost 20 years old...stuff like this is bound to happen but I really like using my fogs..especially in the morning when it's dark out.
Old Nov 29, 2021 | 07:19 PM
Dodgevity's Avatar
Dodgevity
Me too. I use them as running lights.
Old Nov 29, 2021 | 08:02 PM
Tshane72's Avatar
Tshane72
Those are really nice fog lights you got there, I also switched mine out for LED's. Well I hope my problem is something simple. Will try to get to it this coming up weekend.
Old Nov 30, 2021 | 06:40 PM
Dodgevity's Avatar
Dodgevity
How about a few pics of that Rango' you got there? I like the hood scoops and color.
Old Dec 1, 2021 | 06:09 PM
Tshane72's Avatar
Tshane72
Thanks..here are a couple of pics...had her repainted last year in the original colors.
Old Dec 1, 2021 | 07:05 PM
Dodgevity's Avatar
Dodgevity
Looks great, bro.
Old Dec 1, 2021 | 07:17 PM
Tshane72's Avatar
Tshane72
I see you have the same drive train as me, All I have ever done to this motor is change the plugs and oil at regular intervals...runs like a top. Never gives me any troubles.
