Fixed heater core. New problems :(
Throwing my $0.02 in on this one.....when I had to replace the fan motor and resistor on my 2000 Durango (4x with the 4.7 but should be pretty spot on for vacuum lines) there was a "reservoir" for the vacuum under the cowling below the wiper arms on the passenger side. If memory serves me correctly that is the vacuum for the cruise.....the one on the drivers side below the heater core should serve the controls for the heater. You can take the dash face off and pull the gauge cluster and most likely the radio for room (and maybe the lower kick panel below the steering column) to get at the vacuum lines for the heater controls. I will see if I can link my post to this reply and put some pics up if I still have them....
*** Edit *** my actual pictures are not much help nor is my earlier post that I put up about changing out my fan motor and the blower resistor, but I DID find the vacuum diagram that I used when trouble shooting the issue:
Simplified vacuum hose diagram. Note the multi colored 7 hose connector as depicted in the upper right side of the picture runs from the HVAC controls to the system under the dash
Hope this helps.
Steve
Hope this helps.
Steve
The following users liked this post:
George Genovezos (01-20-2022)
