98Gen1 Abs light, no speedo
Old Oct 9, 2022 | 02:13 PM
DVO's Avatar
DVO
Well finally got scanned and ABS module is bad soooo I will have to send it off to be refurbished and maybe all will turn out good. Will respond with out come when it happens.
Old Nov 10, 2022 | 08:18 PM
willie killagain's Avatar
willie killagain
Thumbs up 98Gen1 Abs light, no speedo
Hi I'm Willie, Any luck on replacing the ABS module? I would be interested in the outcome I'm having the same issues with My 00 5.9 R/T. Thanks and I wish You the very best with Yours. Thanks also to Hey You", for Your great advice not only with this issue,but all the many issues throughout the years that You have helped Us with. Not said often enough but Myself and many Others really do appreciate all that You have helped Us with. Hey You", Thank You!
Old Nov 10, 2022 | 08:52 PM
Never get tired of hearin' that. Thanks.
Old Nov 11, 2022 | 09:45 AM
DVO's Avatar
DVO
Well module can't be repaired so I have to buy another one and have it linked to the car. As of right now I don't nave anything to add for you sorry. Looking to purchase another unit when I can afford it as times are a little rough right at this moment.
Old Dec 27, 2022 | 06:50 PM
DVO's Avatar
DVO
Well new unit installed, still no change. I have so far replaced the rear speed sensor, the VSS. replaced module all to no avail. I scanned today and got a PO500 code which means basically nothing as it could be any of the things I have replaced so I will just drive it till it quits completely and then send it to the scrap yard.
