Crankcase pressure
Old Oct 16, 2022 | 07:30 PM
LeonDuitz2009's Avatar
LeonDuitz2009
Default Crankcase pressure
Hey Everyone,
I swapped out my main seals about 40000km ago and now theyre both leaking again. '98 5.9L 4x4.
Now, I remember reading a thread or post about these older engines building pressue in the crankcase and blowin out the seals. In the same thread it spoke about an oulet on the intake manifold that could be used to help release the pressure.
For the life of me I cant seem to find the thread again.
Is there any truth to this or is my brain lying to me?
Old Oct 16, 2022 | 09:13 PM
PCV system is supposed to keep a bit of vacuum on the crankcase. If it isn't functioning properly, or, you have excessive blow-by, pressure will build instead. Take off the oil fill cap, engine running, and put a piece of paper over it, is it sucking in, or blowing out?
Old Oct 17, 2022 | 08:03 AM
Dodgevity's Avatar
Dodgevity
Originally Posted by LeonDuitz2009
Hey Everyone,
What brand seals did you use?
Old Oct 18, 2022 | 06:10 PM
LeonDuitz2009
Timken seals.
Old Oct 18, 2022 | 06:11 PM
LeonDuitz2009
Thanks Heyyou for the suggestion, I'll be doing this tomorrow to see whats up?
Old Oct 19, 2022 | 11:16 PM
LeonDuitz2009
I did as you suggested, seemed like it was sucking the paper down.
the PCV valve was reslly chattering as well, not at first, but after i pulled from the valve cover and rattled it around it started to chatter afterwards.
Old Oct 20, 2022 | 08:01 AM
So PCV is operating properly. Theoretically. Check the hose between the valve and intake manifold, see if there is oil in there.
Old Oct 20, 2022 | 02:35 PM
LeonDuitz2009
yeah theres a enough to notice and form a drop on the end of the hose at the intake.
Is there supposed to be another hose on the driver side of the intake? I have a port on that side that is simply capped off.
Old Oct 20, 2022 | 05:41 PM
Yeah, the other side should just have an elbow, with a hose that goes to a fitting on the air filter housing. if it's just capped off, that will put more vacuum on the crank case than there should be... Though, I am unsure if that would actually cause any problems.....
Old Oct 20, 2022 | 06:09 PM
LeonDuitz2009
Okay, so the hose coming off the air filter housing goes into a rubber grommet on the driver side valve cover... second pic
