Next problem needing to fix
Old Aug 16, 2023 | 06:49 AM
Torch? Or Torque???
You can do this in a parking lot.... but, if you run into issues, that may cause you some other trouble. I know most apartment complexes really don't care for folks working on their car in the parking lot..... Have a friend with a driveway you would borrow for a bit??
Old Aug 17, 2023 | 10:06 AM
theresajengle's Avatar
theresajengle
Torch? Or Torque???
Sorry, I meant "Torque." u-tube explains that I would need to use a Torque wrench on one of the parts, I was wondering if that is mandatory? I remember when I would frequently work on the front end of my 1972 Chevy 4x4. I had read some where that a certain amount of Torque was needed, with a torque wrench, I didn’t have a torque wrench so I never used one, just like a pickle fork, I never used that either & never had any issues.
My question is, can I do the job without a torque wrench or would that be a bad idea? If I need to use a torque wrench, is there somewhere that I can borrow one like the "tie rod tool?"
I completely agree with you about working on cars in apartment buildings. But, I am confident that if I get everything I need, and it all goes smoothly, no issues arise, I figure I should be able to do it in one day. And I don’t think anyone will complain. Everyone already knows & sees me working on my car all the time. Even the manager complimented me for working on my car.
And yes, I did first try to find a driveway to borrow like you said. But, that didnt pan out.
THANK YOU
Old Aug 17, 2023 | 11:23 AM
Depends on far you are disassembling things. If you are just doing tie rods, and such, likely they want a torque wrench for the lug nuts...... Not an absolute requirement, but, still a good idea to have one. Should be able to rent one from your local parts store, should the need arise.
Old Aug 17, 2023 | 11:51 AM
theresajengle
Yes, im doing just tie rods, hopefully, im checking breaks & everything else I can see. Does anyone know how I can find out how many pounds of torque required for the outer tie rod that connects to the steering knuckle? Is it different for each car?
THANK YOU!!
Old Aug 17, 2023 | 06:25 PM
Tighten em down so they are fully seated, and two grunts. Then, however much more you need to tighten them to get the cotter keys in.
Old Aug 18, 2023 | 08:36 AM
Dodgevity's Avatar
Dodgevity
Tie rod...last on the list.
Old Aug 18, 2023 | 10:16 AM
theresajengle
Thank you
Old Sep 5, 2023 | 01:20 PM
theresajengle
HELLO EVERYONE,
I DID IT!!! (with all of your help of course)
This weekend I rented the torque wrench, tie rod tool & got all the tools I needed & I replaced both inner & outer tie rods with new ones! Went smoothly,
I have an appointment tomorrow at the shop for an alignment. I did drive it around the block to see if anything would fall off… LOL!! otherwise I'm not driving it till I drive it to the alignment shop, it's only a couple miles at most.
I do want to thank you all for the help, I wouldn’t have been able to do it without you all!!!
For sure I will be on to the next task that my car will need and will have more questions to ask...
THANX AGAIN FOR ALL YOUR HELP AGAIN!!
Old Sep 6, 2023 | 09:53 AM
Awesome!
Old Sep 6, 2023 | 12:30 PM
theresajengle
CANT ALIGNED, BAD BALL JOINT
I took my Durango in for an alignment after I just put on new inner & outer tie rods on both sides, the shop said that they cant align it because of a bad upper ball joint on the passengers side.
Looks like im gonna now have to replace all 4 ball joints, both upper & lower on both sides.
Anyone have any advice? What will I need?
Also, the mechanic said that he is 90% sure that I put the outer tie rod in the steering knuckle upside down! WOW! Guess I need to figure that out.
I am concerned about driving it with it not aligned & if the tie rods are upside down. Will it cause harm or dangerous?
