2003 Durango Stock Radio Won't Shut Off
Old Mar 4, 2024 | 11:49 PM
fcastro's Avatar
fcastro
Default 2003 Durango Stock Radio Won't Shut Off
Hi all, working on fixing up a 2003 R/T Durango. The radio on the car (stock) can be turned on even when the key is "off". I figured it was a clock spring issue, so I replaced that, that wasn't the issue. Anyone have any thoughts on what could cause that?
Old Mar 5, 2024 | 09:18 AM
Erm, you SHOULD be able to turn the radio on when the key is on.... do you mean "off" by any chance??
Old Mar 5, 2024 | 09:54 AM
fcastro's Avatar
fcastro
HeyYou, yes I meant the radio can be turned on, even when the truck is off. Sorry was dozing off shortly last night lol.
Old Mar 5, 2024 | 09:56 AM
Ok, that is definitely a problem.
Which Radio do you have? Seems there are three choices there.....
Old Mar 10, 2024 | 06:25 AM
madhu's Avatar
madhu
That's an interesting problem. I don't know about a "circuit breaker" in keeping with se, as the radio will use a fuse, placed at the drivers facet sprint when you open the door.
192.168.100.1 192.168.1.1
Old Mar 12, 2024 | 10:19 PM
James Vining's Avatar
James Vining
@fcastro I'm just winging it here but I would not be surprised if someone connected the Always On wire with the ACC or Ign wire to be able to listen to the radio without a key or without Ign in Acc or /On Position
I would pull the Cluster Bezel , remove the 2 @ 10 mm bolts securing the radio pull it out a bit and inspect the wiring to see if you can spot a modification to the harness.
Old Mar 29, 2024 | 07:12 PM
fcastro's Avatar
fcastro
Just wanted to update. So I pulled the fuse for the radio 6 months back. So the radio wouldn't be turned on accidentally. Forgot that where I put. So put in a new 10 amp fuse. Later I found the other fuse and it was 20. Now I am not sure if that was the cause of why it was still staying on or not. The guy who owned this truck previously wasn't a car guy to say the least lol. Anyways radio is shutting off not sure how a fuse being wrong would cause that or whether it was an electrical gremlin. I had to uninstall an after market alarm. Pulled all the wire clips and sealed with electric liquid tape.
