Oil Pressure
Old Feb 21, 2025 | 04:17 PM
ChRiS_27's Avatar
ChRiS_27
Default Oil Pressure
Hi guys.
I got this oil pressure when enigne is warm at idle. Is that okay? Durango 5.2. No any problems, going strong af but I want to ask about that
Thank u for your replays.
Stay safe guys
Link to the photo: https://drive.google.com/file/d/1_jL...usp=drive_link
Old Feb 21, 2025 | 06:01 PM
Originally Posted by ChRiS_27
Hi guys.
Stay safe guys
Tells me to 'request access'..... Not gonna happen.
Old Feb 21, 2025 | 06:19 PM
ChRiS_27's Avatar
ChRiS_27
Try now please
Old Feb 21, 2025 | 08:53 PM
If that's a fully warmed up idle, that is stellar. The metric readings confused me for a bit though.
Old Feb 21, 2025 | 09:14 PM
ChRiS_27's Avatar
ChRiS_27
What do u mean by that? It should be perfectly vertical?
Old Feb 21, 2025 | 09:19 PM
General rule of thumb is, 10PSI minimum at idle, when fully warmed up, then about 10 PSI per 1000 RPM. Yours looks to be around 30-40 PSI at idle, so, you are most certainly good to go.
Old Feb 21, 2025 | 09:32 PM
ChRiS_27's Avatar
ChRiS_27
When I take this picture at idle was 400/450RPM.
Thank u. you calmed me down, I thought it must be vertical all the time and something is wrong. Of course as soon as I press the gas and start driving it immediately increases to the upper scale.
Old Feb 21, 2025 | 10:08 PM
And that is exactly what it should do. Essentially, so long as the needle ISN'T sitting at the bottom of the scale, you are OK.
Old Feb 22, 2025 | 03:42 AM
ChRiS_27's Avatar
ChRiS_27
thank u once again!
Old Mar 13, 2025 | 07:07 AM
SlowRango5.2's Avatar
SlowRango5.2
Default Low oil pressure
Hi guys.
Stay safe guys
Have you checked your oil level? Might be a lil bit low on oil
