Transmission Help
Old Mar 8, 2025 | 04:10 PM
drew73's Avatar
drew73
So I drove it around for a week and didn't seem to change. I just swapped the sensor out again and still didn't seem to help the problem. Any suggestions?
Old Mar 8, 2025 | 04:35 PM
Still getting the code for it? If so, make sure you are getting power TO the sensor, (5 volts, I think, and likely only when the engine is running....)
Old Mar 8, 2025 | 10:03 PM
drew73's Avatar
drew73
Yeah still getting the code. Would I use a normal voltage meter for that.
Old Mar 8, 2025 | 10:06 PM
Yeah, should be a 5 volt supply, the sensor is just a signal generator..... Not a whole lot to go wrong with it.
