Oil pressure tanks after engine gets to operating temp.help!!
Old May 1, 2025 | 07:06 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by STB4LIFE
Well the plenum had one bolt broken on the frontleft or right sitting in the truck. But it had been able to seep air. And now the aluminum is rotted by the hole I'll include pictures the engine has so much carbon build up in it and doing a diesel flush just broke it all loose.
That is definitely sludged up. Have you dropped and cleaned the oil pan? Your pick up tube might have sludge blocking it. The 5.9 in truck didn't look anything like yours. Granted, it did have a flattened can of Schlitz beer and several oil soaked cigarette butts, but not much sludge.
Old May 2, 2025 | 12:42 PM
STB4LIFE's Avatar
STB4LIFE
I've had the pan off twice once just to clean crap out didn't realize I needed to start on top, then again cause I thought it was the oil pump but ur right it just might be the pick up screen and I put that maple syrup oil in it thinking that was the issue being worn.
Old May 11, 2025 | 11:20 PM
STB4LIFE's Avatar
STB4LIFE
All better
All better
Now i could use some torq specs if there out there for the intake i found most of em and also for that plate u see in the picture that hold the cam rollers in had to clean it also
Old May 12, 2025 | 09:56 AM
Grab a FACTORY service manual for your truck. You can generally find them on EBay/Amazon for around 30 bucks.... and it will have TONS of useful information for ya.
Old May 12, 2025 | 09:45 PM
ol' grouch's Avatar
ol' grouch
All better
All better
I dug my manual out.
Intake plenum to intake is three steps. 24 INCH pounds, then 48 in-lbs, then 84 in-lbs. The intake is rather involved. Start in the middle and do bolt numbers 1 through 4 in increments to 72 inch pounds. Then 5 through to 72 in-lbs. Double check all bolts are 72 in-lbs. Then in order torque to 144 in-lbs. It's raather time consuming, but two years later, my intake is just fine.
Old May 13, 2025 | 01:02 PM
STB4LIFE's Avatar
STB4LIFE
Awsome i couldnt find the right process and when id find one it was for the 6 cyl. Ill update if it starts tonight ..
Old May 15, 2025 | 08:08 PM
STB4LIFE's Avatar
STB4LIFE
Default 1st start
Well it started spitting and sputtering. Now it does a high rev and dies oil pressure was about 50 drops to 25 and with some throttle it jumps back up any thoughts. Timing vacume ? Im totally frustrated
Old May 15, 2025 | 09:29 PM
ol' grouch's Avatar
ol' grouch
One thing I did NOT do when I tuned my '96 up was pulled the distributor. Did you synchronize the injectors?
Old May 16, 2025 | 06:56 AM
Moparite's Avatar
Moparite
If you didn't check the pickup screen and you had crap in the pan it's probably clogged. And what weight oil are you using? If you moved or removed the distributor you need to set the fuel sync.
Old May 16, 2025 | 12:51 PM
STB4LIFE's Avatar
STB4LIFE
im using 5-30 oil . And yes distributor was all the way out put a new one in and never heard of the fuel sync process. Learn something new . Whats thw deal with that ?
