weird noise
Old May 12, 2006 | 10:46 PM
RebelX's Avatar
RebelX
Default weird noise
i have a 98 durango 4x4 and here lately when i back up. i get this weird groaning noise. its only when i back up n get around 5mph and it stops after a couple of seconds..its kinda irratating and my mechanic hasn't had time to get it into his shop to take a peek at it.....can someone help me?
Old May 14, 2006 | 08:32 AM
MikeNAmyS's Avatar
MikeNAmyS
Default RE: weird noise
My guess it that it only does it when its cold? Not cold out, but after the vehicl has sat and cooled off.
The whining you are hearing is the pressure regulator in the tranny. It is normal and should go away after the vehicle warms up.
Old May 14, 2006 | 03:06 PM
pinkpanther54494's Avatar
pinkpanther54494
Are you turning while backing up? My Durango groans when I back out of my garage and turn. My guess is that you are hearing the rear differential doing it's normal slipping.
Old May 15, 2006 | 02:10 AM
RebelX's Avatar
RebelX
its only when i back up. wheel direction dont seem to matter any...the durango can be cold or warmed up. it doesn't seem to matter. im suspecting a caliper sticking cause when it did it tonight. i put some slight pressure on the brake pedal and it stopped. so when i get some time during my next 2 weeks of straight work. i'll have to pull off the front wheels and take a peek.
Old May 20, 2006 | 01:50 AM
RebelX's Avatar
RebelX
ok. now its doing it when i go forwards from time to time. and im getting frustrated. still haven't had time to check the brakes. could it be driveline somewhere? its almost a groaning noise. really annoying. hit me up pls
Old May 20, 2006 | 06:14 AM
28this's Avatar
28this
I just recently had a problem like this with my Jeep WJ. If it gets worse sounding especially when you start getting at higher speeds, do you get any kind of vibration also? If so, you need to look at your front drive shaft. It is hard to tell though when you can't see the vehicle. Describe the best you can when and how and what it does.
Old May 20, 2006 | 10:21 PM
RebelX's Avatar
RebelX
it stops after i hit about 5mph. no vibration at all. cold or warmed up. it doesnt seem to matter. its like a groaning noise. but when i apply some brake pressure it seems to stop it...could it be a stuck caliper? or bearings wearing out?
Old May 20, 2006 | 10:51 PM
28this's Avatar
28this
Sounds like it could be a caliper or something stuck between it and the rotor.
Old May 26, 2006 | 03:18 AM
yakkier's Avatar
yakkier
mine does it, it's not the calipers, check your fluid in your tranny, could be that i'v got a minor leak in my oilcooler that whenever my oil gets below a certian level it'll kinda "hmmm" whenever take of in FW or reverse.
Old May 26, 2006 | 03:40 AM
RebelX's Avatar
RebelX
will do that...been noticing lately. it only does it when its hot outside. gonna jack up the front anyways..can hear the brakes squeakin when i stop so i know the pads are prolly worn out.
