Governor on 2000 5.9?
Old Jun 22, 2004 | 04:03 AM
03ramhemi's Avatar
03ramhemi
Default Governor on 2000 5.9?
Someone I know has a 2000 5.9 AWD Durango, and as usual, was bragging how his could beat our new Hemi Durango,and the Hemi isn't all its cracked up to be. So, was wondering if I could beat it, (its my moms but I drive it a lot) ours is the Limited AWD Hemi? Also, he said he past some cars, blah blah blah blah and was at 115 when he was done..can that be true? I thought they had governors at like 110 or less??
Old Jun 22, 2004 | 04:31 AM
dodgemech's Avatar
dodgemech
Default RE: Governor on 2000 5.9?
Speed governor is different for just about every car. 2 identically equipped cars will even be different, one may shut down at 112MPH while the other shuts off at 115MPH
Old Jun 23, 2004 | 06:53 AM
03ramhemi's Avatar
03ramhemi
So, are you saying this one does have one? You know what speed it's supposed to be at?
Old Jun 23, 2004 | 10:36 AM
pkvir's Avatar
pkvir
Race him, beat him, then let me know by how much. Actually, I think he will back down before the race. If his 5.9 is stock, my money is on the HEMI.
Old Jun 24, 2004 | 01:46 AM
dodgemech's Avatar
dodgemech
I can't even get that answer from engineering-don't know what to tell you.
Old Jun 24, 2004 | 05:04 AM
Bamboo's Avatar
Bamboo
The speed limiter is controlled by the PCM and is set at about 110 MPH. From what I've read from other Durango owners it's pretty consistent. If you look at the 1/4 mile times between a 2000 R/T and a 2004 Hemi it's nearly identical. A slightly modified 5.9L would take a stock Hemi in my opinion. I drove an 04 back to back with mine in January on the same road course and speeds. The 5.9 low end is much better but the Hemi above 3,000 RPM's is freaking amazing! It would be a good race and could go either way just because of driver skill.
BTW - my speed governer is set at 128 MPH with the programmer. I've had the speedo pegged at 120 and let me tell you it's all you can do to keep it on the road. Like driving a brick
Old Jun 24, 2004 | 08:45 PM
03ramhemi's Avatar
03ramhemi
Thanks for the replies. I laugh at people like that.
Old Jun 27, 2004 | 07:13 PM
uawnick's Avatar
uawnick
The funny part is that the Durango R/T isnt even the quickest one. The quickest one is the 2wd 4.7 if you can believe it. Only because of the 3.92 rear though. Yep the stock HEMI will spank any other stock Durango their is...
