Durango Blower Switch
Old Apr 21, 2011 | 09:12 PM
  #141
samnbensdad's Avatar
samnbensdad
Could just be a cracked mode cam rather than the blend door.
Old Apr 24, 2011 | 09:12 AM
  #142
davbec1996's Avatar
davbec1996
Default Heater blower
My blower in my 2001 dodge Durango has been intermittently working. I usually just leave it in the on position with it being cold out I would prefer that it work all of the time.
Yesterday when I was driving it wasn't blowing, but it was in the on position. I started smelling something burning. It smelled like a burning electrical smell. I pulled over and looked under the hood and there was a little bit of smoke coming from the passenger side, by the firewall. I turned off the blower switch and didn't smell it again.
We were thinking it was the blower motor getting hot. Any suggestions?
Old Oct 13, 2011 | 06:19 PM
  #143
JohnNoregon's Avatar
JohnNoregon
Smile FORUM rock"s
Gentlemen you guys rock with your help yesterday you helped me fix my 99D with my abs light and speed o and today you fixed my Blower problem's I am a Fan if there was a like button I would click it 100 times
JohnNoregon
Old Oct 30, 2011 | 12:40 PM
  #144
drkveene's Avatar
drkveene
Good Morning,
I have been lurking here for about two weeks or so. I purchased a 2001 Dodge SLT back in August. One of my issues with my 'Rango was that the blower vents did not work. The dealer told me that it was a switch in the dash. I decided to get this fixed when the cooler temperatures started up. I live in Minnesota.
I am not the most 'mechanically inclined' person around. I can do some things (I spent almost 5 days replacing the front rotors and brakes on my old F-150 last year) so after reading about the resistor switch, I decided to give it ago.
Well, it work satisfactory. My vents has 5 positions: Off, low, med, high, highest. After replacing the resistor all but highest position works. I will take this as a victory as the cool weather has hit us this last week or so.
Therefore, my thanks to you who have posted in this thread. I would like to lift the suspension but I do not believe I will tackle that just yet. I do not have a warm place to work (so out in the parking lot) so maybe next spring.
Again, thanks!
Old Oct 30, 2011 | 11:45 PM
  #145
Irondime's Avatar
Irondime
Is it normal that when my blower is on, heat or cool, for it to make a hissing sound every the seconds.
Old Oct 31, 2011 | 04:48 PM
  #146
Irondime's Avatar
Irondime
Sorry my last post should have said every ten seconds it makes a hissing noise. Is that normal?
Old Oct 31, 2011 | 11:29 PM
  #147
chendricks's Avatar
chendricks
I bought a blower motor resistor online via MOPAR. When I installed it, my situation went from no blower to the blower only working at the highest speed. Did I wire it wrong or did I receive a bad resistor?
Old Nov 1, 2011 | 12:27 PM
  #148
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
irondime, it could be that when you have the fan on the vacuum solenoid are attempting to direct the airflow and you have a vac leak int he system, its all that i can think off of the top of my head that would make a hissing sound.
checkdricks, check your plug at the resistor and make sure its not melted and that all of the insulation on the wires is intact if not you may need to replace the wire as well (it is of course possible that you got a bad resistor, but i would chcek the wires first)
Old Nov 1, 2011 | 05:33 PM
  #149
Irondime's Avatar
Irondime
That's sounds right. The hissing noise only lasts a second or two but does it every ten seconds. It's like the noise when you switch the airflow direction setting.
Old Nov 1, 2011 | 05:53 PM
  #150
shrpshtr325
THE ULTI-MOD
sounds like you have a vacuum leak, clearly its not bad yet or it would be a constant hiss, might be worth looking for.
