Throttle Position Sensor Replacement
Old Apr 13, 2009 | 04:37 PM
  #31
MAGIC84's Avatar
MAGIC84
Ditto here, much smoother idle, and throttle body cleaned at the same time. I onlly drive about 8 minutes to work so not much of a chance to determine heat pattern. Maybe I will notice that this winter. IACV may need changing late but I think I may have bought some time. TPS not replaced as of yet maybe next payday but so far idle is smooth so maybe I will just leave it alone for now.
Old Apr 13, 2009 | 05:20 PM
  #32
hydrashocker's Avatar
hydrashocker
Nice to see you got it.
Old Apr 13, 2009 | 06:56 PM
  #33
DragonOfMadness's Avatar
DragonOfMadness
This stuff works excellent at cleaning the crudded up I.A.C's and it'll kill every fricken mosquito and knat fly with in a 30 yard range and breakup noisy bbq's and other parties your neighbors may throw during the summer that **** you off....lol
http://www.seafoamsales.com/deepCreepTech.htm
Old Apr 13, 2009 | 08:41 PM
  #34
IndyDurango's Avatar
IndyDurango
In 200,000+ miles, I have SeaFoamed once. Smoked like a house fire. I have never replaced the IAC.
IndyD
Old Apr 19, 2009 | 01:46 PM
  #35
cyborg67's Avatar
cyborg67
Default tps
hello everone (yes i am a noobie) where is the tps located at on a 98 durango ? thanks for any help in advance
its a 5.9 slt 4x4 thanks
Old Apr 19, 2009 | 01:53 PM
  #36
DRO318's Avatar
DRO318
What size engine do you have?
Old Apr 19, 2009 | 02:03 PM
  #37
IndyDurango
On the '98... it's the 5.2 and 5.9. TPS is in the same place.
There are three sensors on the TB. The one on the driver side is the Throttle Position sensor, the one in the back is the Idle Motor, and the one in front is the MAP sensor. You will need a #25 torx wrench.
HTH,
IndyDurango
Old Apr 20, 2009 | 08:37 PM
  #38
hydrashocker
DRO318<------- Hydra's slapin ya face!........LOL..... ^Look up^...
Old Apr 21, 2009 | 08:42 PM
  #39
DRO318's Avatar
DRO318
Yeah I try not to reply to that guy...
I was tryin to create some conversation since the info wasn't posted
Old Apr 21, 2009 | 11:10 PM
  #40
hydrashocker
Skimey!!!!!!!!!!!!!
Didn't see the edit.........LOL........ Still, I din't mind smackin ya around!.......LOL
