Difference's in 4X4 PT, Low, Hi, AWD
Old Dec 6, 2006 | 01:34 AM
  #31
spudsterier's Avatar
spudsterier
Default RE: Difference's in 4X4 PT, Low, Hi, AWD
31x10.5-15
bfg all terrains
Old Dec 6, 2006 | 04:38 AM
  #32
ILLXJ's Avatar
ILLXJ
but what i was wondering, is how long can you keep it in 4high when there isnt snow on the road..but say maybe there is about 2 miles down the road?????but anyways, how long can you keep it in 4 high without slippery roads???
On dry pavement put it back in 2wd. When you get to the snow shift back into 4HI. JIM.
Old Dec 6, 2006 | 11:09 AM
  #33
spudsterier
so is it bad for the transfer case to be shifting in and out of 2wd and 4wd.....or is it worse to just keep it in 4wd????
Old Dec 6, 2006 | 12:54 PM
  #34
hydrashocker's Avatar
hydrashocker
Only use 4X4 when you need it. I like to stop when engaging or disengaging 4X4. JI don't care if the transfer case is shift on the fly or not I still stop. Also I shift into 4X4 and put it in drive then reverse then drive to make sure it is locked in. Pulling it out back into 2wd I always stop shift, put it in drive, reverse 20 yards, then drive. I have had problems in muti vehicles with shifting in and out of 4X4 so I always take extra time to make sure it is in and out.
As for being bad on the transfer case, I think it would be worse to drive on dry pavement in 4X4 then to shift the transfer case.
Old Dec 6, 2006 | 03:39 PM
  #35
spudsterier
ok well that helps out a bit...thanks
Old Dec 6, 2006 | 05:41 PM
  #36
jonnymagnum's Avatar
jonnymagnum
just to make this clear. if theres like a 20-50ft section of dry pavement and the rest is snow covered. you dont have to take it out and put it back into 4wd just for that small section do you?
________
THE AMAZING RACE FORUM
Old Dec 6, 2006 | 07:43 PM
  #37
Mean Green's Avatar
Mean Green
I would if you are making turns. I always shift on the fly because when I was in NY the main streets would be cleared pretty well but the residential streets wouldn't even be plowed because of how tight some of them were.
Old Dec 8, 2006 | 07:42 AM
  #38
ILLXJ's Avatar
ILLXJ
In a straight line there is no need to go back into 2wd on a dry patch. In the corners shift back into 2wd. You can go into 4HI up to 55mph, but if you need 4x4 you shouldn't be going that fast anyway. Shifting the x-fer case on the fly will not hurt it. Leaving it in 4x4 on dry corners will. JIM.
Old Dec 29, 2006 | 11:17 PM
  #39
ONEENVY's Avatar
ONEENVY
so its okay to put it in 4 when im in drive? i always park put it into 4 then go. sometimes do the reverse then drive thing. i was never sure if it would hurt my d if i shifted into 4 while doing 30mph down the road. This helps. thanks guys!
Old Dec 30, 2006 | 04:14 AM
  #40
Mean Green's Avatar
Mean Green
You can shift while going betweeen 5 and 45 mph I'm pretty sure. I personally wouldn't go all the way up to 45 and shift I go slow when I want to change into 4wd.
