99 dodge durango
Old Oct 8, 2006 | 03:19 AM
kenneth1011's Avatar
kenneth1011
Default 99 dodge durango
how do you get the abs speed sensor on the rear axle out to replace it
Old Oct 8, 2006 | 04:14 AM
IndyDurango's Avatar
IndyDurango
Default RE: 99 dodge durango
Its right on top and easy to do. I posted here before on it. Look it up via a search on my posts.
It will take you longer to get under the D and find it than to replace it.
HTH,
IndyD
Old Oct 8, 2006 | 04:21 PM
hydrashocker's Avatar
hydrashocker
ORIGINAL: IndyDurango
HTH,
IndyD
True
Old Oct 13, 2006 | 03:31 PM
baddiesel's Avatar
baddiesel
one 10mm bolt and pulls right out
Old Oct 13, 2006 | 07:22 PM
steve05ram360's Avatar
steve05ram360
mine had a bracket on it... and it was pretty fragile. becareful pulling it out not to drop anything into the housing and also make sure you dont break the new one on the install...
Old Nov 27, 2006 | 02:39 PM
Wredheadgirl's Avatar
Wredheadgirl
Junior Member
Is this the only speed sensor? I have a check engine light on because of a speed sensor malfunction and am trying to figure out if this might possibly a fix it at home issue. Supposedly one mechanic told me it was a speed sensor in the transmission? Does that sound right?
Old Nov 27, 2006 | 02:44 PM
steve05ram360
there is another in the tranny, this one is responsible for the speedo...
Old Nov 27, 2006 | 11:56 PM
baddiesel's Avatar
baddiesel
when my rear speed censor went bad only had abs & brake light on, no check engine
