speakers
RE: speakers
Ok, it took a while, but I finally got the 62.7i speakers installed in the rear doors. The install took about 20 minutes (I could not find my bits for the driver....) othewise would have only taken about 10 minutes. The adapters that came with the speakers were a perfect fit and the install was a breeze. Now....when i turned the truck stereo on, the sound was about the same as the 4ohm Blaupaunkts that I had put in there previously....the volume is low on the rears. I know question whether or not the rear channel on the factory amp is fading away on me..if that is possible. The front seems to be twice as loud as the front. I don't think I am getting the full effect of the Infinity's ability. I am still going to look into this and see what happens after I install the Infinity's that I bought for the front, the 60.7cs...looking forward to getting my sound back.
RE: speakers
Ok, finally completed the install of the front speakers, 60.7cs, in my D and the difference is night and day....The install was extremely easy, all brackets were included and fit like it was from the factory. I took the extra time to solder everything, but even with that, it only took 30 minutes to do this. If you have never had seperate tweeters, it may take a little bit of time for you to get used to the difference between component speakers and regular 6.5" speakers. The sound is great, but don't expect alot of bass from this set up. The mids and highs sound great (for being used with the factory head unit and amp). They would probably sound better with a high end amp, but as it sits, its my daily driver so I am not gonna drop mega $$$ into the sound system...(been there, done that.....)....all in all, I would definitely recommend these to anyone looking for an upgrade/replacement for there stockers....
RE: speakers
The only burp I have is the OEM infinity speakers had a better deeper bass response than the aftermarket Infinity's!! But the aftermarket Infinity's have a much crisper full range sound overall tho. I am happy with them. I am currently using Infinity 6012's and those speakers did not come with the 3 ear adaptor ring to make it fit my OEM speaker spacers. Without that OEM spacer, the speaker would not have fit the opening due to the window rail being in the way (depth wise). Luckily I was able to find someone that makes those custom rings to adapt my Infinity 6012's to the OEM spacer so I can now use any kind of 6.5 inch speaker. I will look around and find a 6.5 inch speaker with a very long (deep) bass cone driver to see if this improves bass response. I had all 4 of my OEM's changed to the 6012's. The 6012's are 4 ohm speakers. You can always add a higher resistance speaker on a lesser resistance amp system, but not the other way around.
Also, the sound difference between the front and rear is noticable in my Infinity system as well since the day I bought this Durango. The fader is set where all 4 speakers equally get the same sound volume. This must be by design where the fronts are naturally louder only to benefit the driver mainly I guess.
RE: speakers
ORIGINAL: viperbob
I just did all of this on a '98 D. Went with 63.7s (just a few $$s more) and they worked great. Easy install. Got the two pairsoff eBay for a total of about $200.
