Torsion Bar Lift
Old Dec 2, 2009 | 12:14 AM
  #81
mrwilliwizard's Avatar
mrwilliwizard
are they the belltech 6700 shackles or the 6400 shackles? or do either ones work?
Old Dec 2, 2009 | 02:31 PM
  #82
mrwilliwizard
my bolts look like they are already fully screwed in. or do they just look like that? suspensions never been touched before. or do i have to lift the car off the ground first to see how far they are screwed in?
Old Dec 2, 2009 | 07:52 PM
  #83
DirtyDurango's Avatar
DirtyDurango
users that are running 33s... do you just have the T/S lift or are you sittin' higher? i wanna know because if i can run 33s with just the T/S then i'm gonna.
Old Dec 3, 2009 | 12:59 PM
  #84
hydrashocker's Avatar
hydrashocker
To run 33's you need to also intall a 3" body lift and T/S lift. Also understand that you need 2" offset rims from OEM for the 12.5 tires.
Old Dec 3, 2009 | 05:06 PM
  #85
DirtyDurango
alright, i was just gonna get the 10.5 anyway
Old Dec 29, 2009 | 08:33 PM
  #86
mrwilliwizard
do they have the 9/16 washers at home depot maybe?
Old Dec 29, 2009 | 10:25 PM
  #87
hydrashocker
I'm sure they do but I would get Fender Washers so they are the same height as the bushing and I'd do Stainless Steel. Place 1 regular washer in up against the bushing then the rest fenders unless there is enough room that the metal casting does not come in contact with the washers so no squeak or bind.
Old Dec 29, 2009 | 10:41 PM
  #88
mrwilliwizard
oh ok thanks. how would i find the right size tho? the hole on the washer needs to be the right size do i just mix and match? until one fits?
Old Dec 30, 2009 | 04:22 AM
  #89
dledger71's Avatar
dledger71
I am running 33's on my Add-a-leaf and T/Bar lift... did a little inner wheel well trimming but I run them with no problems!! No rubbing at all.
Old Dec 30, 2009 | 10:18 PM
  #90
hydrashocker
You will need 8-10.......9/16" washers. Get 4 regular 9/16 ID small washers (not locking washers) and 8....9/16 regular fender washers (which are larger OD but the same 9/16 ID). Just ask the parts guy if your not sure.
