tranny swap is done...
Old Apr 29, 2007 | 08:53 PM
Leonheart17240's Avatar
Leonheart17240
Default tranny swap is done...
i did the atx to mtx swap last night and so far so good... i have 3 lights on in the dash now! a cel and a door ajar and a brake light... i left in the atx pcm for the time being is that the reason that i have thes lights??? p.s. my rev limiter is still 6750... not 4500???
Old Apr 29, 2007 | 10:53 PM
spudsterier's Avatar
spudsterier
Default RE: tranny swap is done...
that should be the reason that your check engine light is on....as for the others, i would have to say no...
why would your rev limit be 4500????
Old Apr 30, 2007 | 01:07 AM
jakedlee16's Avatar
jakedlee16
yeh dude who said rev limiter was tht ? o well im might do the swap soon too
Old Apr 30, 2007 | 01:09 AM
Leonheart17240
The atx pcm, i read somewhere that it will be around 4500... idk maybe i didnt read it right
Old Apr 30, 2007 | 01:17 AM
Leonheart17240
"if the pcm reads the TQ as being in park or neutral then your rev limit will be stuck at about 4,000-4,500rpm's " idk i just figured that it would be stuck there... thats my luck most of the time.... o by the way what gear oil do you put in the 5 sp?
Old Apr 30, 2007 | 10:09 AM
spudsterier
get some mopar atf+4
if you unplug the atx pcm, then most of the time it will be stuck in a drive gear
Old Apr 30, 2007 | 11:38 AM
das2123's Avatar
das2123
Congrats on the swap. Do you need an MTX PCM?
Old Apr 30, 2007 | 10:29 PM
Leonheart17240
yes, but i am tring all the junk yards around here first... got a Q? about the mopar pcm were is the rev limiter a gov???
Old Apr 30, 2007 | 10:32 PM
Leonheart17240
ok also what weight is the tranny oil??? as of the last 2 days i have 75/95 in it plz tell me i am not killing it
Old Apr 30, 2007 | 11:45 PM
das2123's Avatar
das2123
ORIGINAL: Leonheart17240
http://www.modernperformance.com/dcx/mopar_pcm.shtml
