surviving through mods
Old May 4, 2007 | 04:21 PM
  #41
spudsterier's Avatar
spudsterier
Default RE: surviving through mods
whos opinion?????
Old May 4, 2007 | 04:33 PM
  #42
QuiK615's Avatar
QuiK615
lol nvm it was a joke you obviously didnt get more like sarcasm but whateva
Old May 4, 2007 | 04:59 PM
  #43
brute's Avatar
brute
The pulley doesn't balance the engine, that is correct. However, it does dampen harmonic oscillations on the crank shaft. What happens is waves travel along the crankshaft, parallel to it's rotational axis. If nothing absorbs that wave, then it will reflect and meet the next wave traveling in an opposite direction. This is obviously the need for the harmonic damper. It has rubber along the inside to absorb the slight waves. If your rubber degrades over time, as it has an awful tendency to, the waves cease to be damped and can actually get so violent that it tears the rubber out of the actual pulley. I've seen it happen.
Old May 4, 2007 | 05:14 PM
  #44
das2123's Avatar
das2123
ORIGINAL: brute
On a neon?
And again, I have seen thousands of miles put on neons with UDP's with no problems, but if you wanna say we shouldn't put them on, fine. But I will continue to take advice from other people in the neon world who have been doing it longer than me.
Old May 4, 2007 | 05:39 PM
  #45
dysphagia's Avatar
dysphagia
ORIGINAL: das2123
because we all know the neon community is the pinnicle of automotive know-how including harmonic oscillations along the crank
Old May 4, 2007 | 05:42 PM
  #46
das2123's Avatar
das2123
ORIGINAL: dysphagia
ORIGINAL: das2123
I don't use the advice or info for all automotive know-how, just the neon. What I drive!
Old May 4, 2007 | 05:44 PM
  #47
dysphagia's Avatar
dysphagia
so the opinions of neon drivers are more important than the basic principles of engine dynamics?
Old May 4, 2007 | 05:45 PM
  #48
brute's Avatar
brute
ORIGINAL: das2123
What I drive!
That's understandable, however, I fail to see the reasoning of just getting to know one type of automobile. There are so many shared parts and theories amongst models and even brands; there is no reason to keep a closed mind and not try to further your learning.
Old May 4, 2007 | 05:49 PM
  #49
QuiK615's Avatar
QuiK615
this is a neon forum stfu with all ur other junk
Old May 4, 2007 | 05:51 PM
  #50
das2123's Avatar
das2123
ORIGINAL: dysphagia
No, but their lengthy experiences with building, racing and working neons does. I don't know how many times I have to say it...the UDP has been proven not to hurt/reduce the neons engines life.
ORIGINAL: brute
ORIGINAL: das2123
What I drive!
I won't be working on other cars, so why the need to learn about them? Some facts maybe, but I'm not concerned with learning about them.
