No SPARK!!!
Old 05-23-2007, 10:53 AM
hnda8r's Avatar
hnda8r
hnda8r is offline
Default No SPARK!!!
Well heres an update. Finally got the wiring harness on and replaced the coilpack. And the car still wont fire up!![:@]Its not getting any spark. So we switched out the cam sensor, and some other sensor thats on the front of the block(cant remember what its called), and still no spark. So we switched out the spark plug wires, nothing. The only thing we didnt switch yet is the PCM. We ran a test light over everything, and the only place that is not getting power is 2 little prongs that are on clip that connects to the coil pack. The car did spit up codes: 11, 22, 42, 55 But we are totally stumped!!! How is it not getting power to the coil pack. If anyone has any insite on this please let me know, Im really close on giving up and selling it. I have been trying to collect parts and info to restore this thing for 3 months nowand its just not working.please help. Ill try to answer any questions yall have. thanks.
Old 05-23-2007, 01:54 PM
das2123's Avatar
das2123
das2123 is offline
Default RE: No SPARK!!!
Have you checked the ASD relay?
Old 05-23-2007, 02:25 PM
hnda8r's Avatar
hnda8r
hnda8r is offline
I will as soon as you tell me what ASD means.
Old 05-23-2007, 02:40 PM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: hnda8r
Auto Shutdown Relay.
Old 05-23-2007, 03:26 PM
hnda8r's Avatar
hnda8r
hnda8r is offline
ok, Ill def check it out tonight, and let you know
Old 05-23-2007, 04:28 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
did you replace the crank sensor?????
if that doesnt work then i would suggest the pcm..... though usually when the pcm encounters an internalproblem, it will blow the fuel pump fuse, so im not entirely sure on that
Old 05-23-2007, 04:41 PM
hnda8r's Avatar
hnda8r
hnda8r is offline
Yup I replaced the crank sensor, the only thing I didnt replace is the PCM. Im going to check what das told me to, this afternoon. Ill also check the fuel pump fuse. Thanks
Old 05-23-2007, 06:27 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
Wow, this still sounds just like my problem. I have done everything you have, including the pcm[:@] That is why I am thinking it is the pdc, I am getting enough fuel to power a damn 426 for a week[:@]
Old 05-23-2007, 06:28 PM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: hnda8r
The fuel pump fuse being out wouldn't keep you from getting spark.
Old 05-23-2007, 06:35 PM
hnda8r's Avatar
hnda8r
hnda8r is offline
Oh ok..... Ill check it anyway, it wont hurt to.
Quick Reply: No SPARK!!!
