Searched Searched And Searched Some More
Old Jun 14, 2007 | 11:03 PM
boxerjl2's Avatar
boxerjl2
Default Searched Searched And Searched Some More
i searched all over the forum to find out how to get the Vss Gear out of the tranny
do i have to take the tranny apart and if so were at
there are alot of bolts on it
please help and is this part buyable at a Dealership Parts store ???
Old Jun 15, 2007 | 01:45 AM
spudsterier's Avatar
spudsterier
Default RE: Searched Searched And Searched Some More
ontop of the tranny in the back.......there is 1 bolt that holds the sensor part down.....pul it up carefully and the gear will be stock on the end of it.......
Old Jun 15, 2007 | 02:36 AM
das2123's Avatar
das2123
ORIGINAL: boxerjl2
Yes it is, but you will have to splice the new connector on there. You may not have to do this with the OEM one from the dealer.
Old Jun 15, 2007 | 05:15 AM
boxerjl2's Avatar
boxerjl2
NO I DROPPED THE GEAR INTO THE TRANNY
the part that hooks to the sensor
i know how to change the vss Spud
but the gear that goes on the end of it fell down into the tranny through the hole were the sensor mounts
Old Jun 15, 2007 | 05:38 AM
95neonriceeater's Avatar
95neonriceeater
Old Jun 15, 2007 | 10:19 AM
spudsterier
ORIGINAL: boxerjl2
well that wasnt explained in the 1st post....
i have had that problem before....i could stick my finger in there and move it back to where i could get it out with a pair of pliers.......
i also had one before that i couldnt get the gear after it fell in there......so i just left it and put a new gear in there.....good thing it was plastic.....about a year later i took the tranny apart and there was the gear, all flattened out, but didnt hurt the tranny
Old Jun 15, 2007 | 01:24 PM
boxerjl2's Avatar
boxerjl2
ok so were did you get the new gear???
Old Jun 15, 2007 | 01:50 PM
boxerjl2's Avatar
boxerjl2
ive always heard dealers suck
so i was kind of weary of haveing to buy this part thinking that they would over charge but it was only 4 bucks
yeah
so no transmission injury could happen???
does the speed sensor control the tack becuz since i took it out my tach is crazy bouncing every were
and if its not the VSS then were is the Tach Hooked To ??
Old Jun 15, 2007 | 04:01 PM
spudsterier
the tach gets its reading through the pcm and from the coil pack
im not gonna say that YOU wont have any tranny problems......im just informing you that i didnt
i ended up getting my new gear from a tranny that i had sitting around......i think i have 4 extra gears now
Old Jun 15, 2007 | 04:35 PM
boxerjl2's Avatar
boxerjl2
hey spud i figured i explained it there by sayiung the VSS gear not the VSS itself
