Switching From Lock Your Door!! to Automatic Possible??
Old 06-19-2007, 03:11 PM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
Default Switching From Lock Your Door!! to Automatic Possible??
ok right now i have manual locks and window i dont mind the manual windows but is it possible to get auto locks for a car thats ment to have manual locks??
let me know cuz i really want auto lock door were i can just push a button
Old 06-19-2007, 03:29 PM
chenzo's Avatar
chenzo
chenzo is offline
Default RE: Switching From Lock Your Door!! to Automatic Possible??
why does every topic!!! you ever start?! or contribute to!!always broken?? up with random??!?!punctuation?!? it gets really!!! annoying?!?!
Old 06-19-2007, 03:57 PM
das2123's Avatar
das2123
das2123 is offline
Yes it is. 1st thing you should do is check to see if you have the wiring pre-installed.
Originally Posted by ErikJohnson[/align] On the front door, either passenger or drivers, locate the rubber hose that wires pass through the car to the door. What you need to do is pull off that rubber hose from the a-pillar. Then, take a flat head screwdriver and pry out the plastic plug that snaps into the a-pillar. You are looking for a bunch of wires, on the dashboard side of this plug that I just had you pop out. If you have what looks to be every pin on the car side of the harness, you have the easy route. If you only have the two speaker wires, you will need to either get a harness out of a car that has the power options, or you will need to run each wire yourself between the doors...not fun![/align]
Old 06-19-2007, 11:50 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
if you have the wires alredy to the door, then you will need the door wire harness, door panel, power lock switch, lock actualtor and possibly the metal rod that connects to the actuator
Old 06-20-2007, 04:46 AM
protivakid's Avatar
protivakid
protivakid is offline
While you are already doing this why not buy a keyless entry kit. They are pretty cheap yet still work great. My friend bought one for $40 on e-bay and it has worked for a couple years now anyway, said the install was very easy.
Old 06-20-2007, 05:13 AM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
sorry... for ?? my Pun..ctuation Pr,oblems Im really ... trying
ill check out my car tomorrow and see if i got what i need and hopefully i get my speedo fixed and from now on i just wont use punctuation
and i dont see random punctuation there are two question marks
Old 06-20-2007, 05:15 AM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
oh i get it my topic name
Old 06-20-2007, 06:20 AM
estneon's Avatar
estneon
estneon is offline
man your lazy why do you want to just push a button then again most of my cars are two door.don't get a keyless entry kit you might hook it up to your horn knowing you lol.
Old 06-20-2007, 05:20 PM
protivakid's Avatar
protivakid
ORIGINAL: estneon
Haha are you referring to my wiring problems of the past?
Old 06-20-2007, 05:43 PM
estneon's Avatar
estneon
estneon is offline
no boxer's skill of working on a car.lmaoj/k boxer.you could probably do it but it would be intresting to see when your done.we all have wiring problem some times even the pros.
Quick Reply: Switching From Lock Your Door!! to Automatic Possible??
