crank pulley install!
Old Jul 1, 2007 | 05:27 PM
neoncrazy101's Avatar
neoncrazy101
Default crank pulley install!
how do u get the crank pulley back on?
Old Jul 1, 2007 | 05:36 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: crank pulley install!
Just put the pulley on the crank, if you have to, tap it a little bit with a brass hammer, then just put the bolt in and tighten er up! Alot easier than taking it off[:@]
Old Jul 1, 2007 | 05:37 PM
neoncrazy101
i tried that. still didn't get it on all the way to where the bolt could reach the threads....
Old Jul 1, 2007 | 05:44 PM
Jr. Mechanic
I know mine I only had to have it on a 1/4 inch and my bolt reached the crank[&:] If not, go to the auto parts store and they should have a kit that is made for it, it will have studs that screw into the crank and then it has a threaded end for the stud and a big end, should be about 7/8 that you put a wrench on, and it has a washer with the pulley under it. As you turn it, it will push the pulley on.
Old Jul 1, 2007 | 06:24 PM
neoncrazy101
^ still wasn't big enough. none of their screws could fit. this is really beginning to irritate me.
Old Jul 1, 2007 | 06:26 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
you can either get a longer bolt that threads in more and use an impact gun on it. or maybe clean the surface with a wire brush till your arms are tired and do that or heat up the pully in the oven to about 250 deg and slide it on that way
Old Jul 1, 2007 | 07:26 PM
Jr. Mechanic
Yeah, like garrett said, I would just go and find another bolt that is longer, just remember, it is metric so a 3/8 inch bolt wont work, good luck finding one that long
Old Jul 1, 2007 | 07:54 PM
DOHCgarrett t3
if you heatit up and use the wire brush you should be alright with it sliding on far enough that you can thread the bolt on there
Old Jul 1, 2007 | 10:29 PM
neoncrazy101
finally got it on. i used the oven lol. thanks guys.
