heater Core is for the A/c To ??
Old Jul 4, 2007 | 02:46 AM
boxerjl2's Avatar
boxerjl2
Default heater Core is for the A/c To ??
ive been looking around on the internet and i dont know if there is a heater core that does both
or if they all just do both cuz i dont want to buy a heater core that only does heat
but if you dont need a heater core for A/C then just kill me know
Old Jul 4, 2007 | 07:23 AM
spudsterier's Avatar
spudsterier
Default RE: heater Core is for the A/c To ??
the heater core would be for the heat only.....hot coolant flow through it and when the blower blows airthrough it, you get heat......
Old Jul 4, 2007 | 12:55 PM
boxerjl2's Avatar
boxerjl2
so how come when i bypassed the heater core i no longer have an A/C????
Old Jul 4, 2007 | 01:15 PM
spudsterier
how did you bypass the heater core?????
Old Jul 4, 2007 | 01:16 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Must have been a coincidence, the heater core is the same thing as a radiator, but smaller under your dash that as the hot coolant comes in, it heats the copper /aluminum coils and then the blower fan blows air over it, giving you heat. The a/c is a totally different unit, It uses its own coils and condenses the air... Try recharging your a/c and it should work.
Old Jul 4, 2007 | 04:41 PM
boxerjl2's Avatar
boxerjl2
i bypassed it by takint off the two tubes from the firewall or watever you wanna call it and hooked them together
how much to get it recharged??
Old Jul 4, 2007 | 04:44 PM
boxerjl2's Avatar
boxerjl2
since i boght this car and really no nothing about it is it possible for the previous owner to have taken out the A/c or is that impossible??
Old Jul 5, 2007 | 01:53 AM
Likemyjunk's Avatar
Likemyjunk
Well... Is the AC compresser still there? Is all the lines attached to it? Is there a thing that looks like the radiatorplaced in front of it? The AC lines should be running into it. If so then I would bet that the AC system is still there.
It is very possible to completly remove all of the AC system. Matter of fact some people do, I prefer to have some cold air myself. As for diagnosing the AC system, someone else will have to explain that. I don't have enough knowladge in the matter really. I can mess it up good and proper for you though lol.
As for the heater core. All you did was as you said bypassed it. Nothing to do with the AC when connecting the two heater core lines together.
But... Why did you have to bypass it? Was the Core leaking or maybe some constant hot air blowing?
Old Jul 5, 2007 | 02:38 PM
boxerjl2's Avatar
boxerjl2
the heater core broke and i was leaking fluid all over my floor
Hmm ill have to look up the ac and see what it looks like then go under the hood and find it
