Engine removal w/o tranny
Old Jul 20, 2007 | 12:03 AM
Aerorat's Avatar
Aerorat
Default RE: Engine removal w/o tranny
Not sure of that one
Old Jul 20, 2007 | 07:54 AM
spudsterier's Avatar
spudsterier
im not sure about the engine weight....without the head, i can lift the block by myself and set it on a table and 2 people can lift a fully assembled motor fairly easily.....
your chain location should be fine.....i usually go front to back....and i have actually used 1 of the intake manifold bolts and 1 of the bolts that hold te power steering resivoir to the head
Old Jul 20, 2007 | 08:25 PM
junkie97neon's Avatar
junkie97neon
Engine out just fine, got the head off as well. Will post pics of head. Thanks again for all your help!!!
Old Jul 20, 2007 | 08:37 PM
Aerorat's Avatar
Aerorat
while you got that off i would get it checked to make sure it is square and if not get them to surface it.
Old Jul 20, 2007 | 08:52 PM
junkie97neon
Yeah, I plan on getting it right. The entire reason I pulled it is becuase the water pump locked up, breaking the timing belt. So I decided to pull the head to check the valves, plus several seals/gaskets were leaking.
Old Jul 20, 2007 | 09:00 PM
NYG's Avatar
NYG
ORIGINAL: junkie97neon
Are you having Fun Yet?
Old Jul 20, 2007 | 09:28 PM
junkie97neon
Yes, fortunately for the most part I am. Never pulled a car engine, or had the heads off. Wonderful learning experience!!!
Old Jul 20, 2007 | 09:53 PM
spudsterier
you wouldnt like it as much if you had to do it on almost a normal schedule like i do[:@]
Old Jul 20, 2007 | 10:24 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Well maybe if you were nicer to your cars
Old Jul 20, 2007 | 10:35 PM
Aerorat's Avatar
Aerorat
I can relate. I am glad i don't do it for a living though.
But when you fix your own stuff you take much more pride in it. My hat is off to junkie97neon for jumping in with both hands. Getting dirty and learning to do it by himself
