evaporator core removal
Old Aug 26, 2007 | 07:07 PM
hoosierneon's Avatar
hoosierneon
Default evaporator core removal
Has anybody replaced this without removing the whole dashboard.
Old Aug 26, 2007 | 07:55 PM
Aerorat's Avatar
Aerorat
Default RE: evaporator core removal
nope it has to come out
Old Aug 27, 2007 | 12:48 PM
boxerjl2's Avatar
boxerjl2
is that a heater core?? the evap core??
i still dont know how to take the entire dash off
but this is not my post but since it is the same subject if you change the heater core yourself do you still have to take it to a shop to get it recharged??
Old Aug 27, 2007 | 12:52 PM
teetdogs's Avatar
teetdogs
I am pretty sure that the heater core doesn't need to be charged as it takes heat from the care, The A/C on the other hand can be recharged. and that you can do by yourself at least I did with one of the cans of freon from O'reilly.
Old Aug 27, 2007 | 12:53 PM
Aerorat's Avatar
Aerorat
for the heater core???????
no
Old Aug 27, 2007 | 01:04 PM
boxerjl2's Avatar
boxerjl2
ok well the shop im taking my car to says this "well it will cost $300 for the time $100 to recharge it and then plus the cost of the heater core"
which the cheapest heater core ive found is for $70
http://replacement.car-stuff.com/par...howdc=true#top
so it doesnt need to be recharged.. hmmi think ill just try to do it myself then... and i have the manual so it should help me out some.. and i can save myself $400
Old Aug 27, 2007 | 01:16 PM
Aerorat's Avatar
Aerorat
unless they are ripping you off and calling torecharge is to refill you rad back up with water and antifreeze because that is what runs through the heater core. Basicly it is just a small rad. If it is the evaporater core for the ac the system will need to be completely discharged and then recharged after repairs are done.
Old Aug 27, 2007 | 03:33 PM
boxerjl2's Avatar
boxerjl2
well i think im just gonna do it my self
