gettin tuned?
Old Sep 7, 2007 | 12:51 AM
neon527's Avatar
neon527
Default gettin tuned?
97 SOHC MTX, is it possible or if it is a good idea to just get theATX ECU tuned to the specs of a MTX ECU? maybe evenDOHCspecs
Old Sep 7, 2007 | 01:08 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: gettin tuned?
you cant get the stock pcms tuned
Old Sep 7, 2007 | 08:36 PM
neon527's Avatar
neon527
so i guess either way i need to get a aftermarket pcm from mopar right?
Old Sep 7, 2007 | 08:43 PM
das2123's Avatar
das2123
Either that or an AF/x PCM from Howell automotive or use Megasquirt.
Old Sep 9, 2007 | 01:29 AM
neon527's Avatar
neon527
i hear around town that i should take it to the dealer n get it reflashed as a mtx ecu and get it upgraded from then on,, possible?
Old Sep 9, 2007 | 03:30 AM
racerx55's Avatar
racerx55
it will probly cost you more to get it flashed at the dealer, if they even do it, than to buy a used MTX pcm.
you can get them for around $50 at a junk yard, sometimes less.
find one from an r/t if you can, they have a little more agressive tuning
Old Sep 10, 2007 | 08:35 AM
das2123's Avatar
das2123
ORIGINAL: neon527
The dealer will not "flash" the PCM to upgrade it. Thats what the Mopar PCM is for.
Old Sep 10, 2007 | 09:02 PM
neon527's Avatar
neon527
aight guys thanks for all ur help!!!til next time
