battery to trunk
Old Sep 17, 2007 | 07:14 AM
spudsterier's Avatar
spudsterier
Default RE: battery to trunk
there are vents in the corners by the taillights.....if you take off the back bumper then you will see them..
i havent hooked up a vent yet, mostly since the top of the battery box isnt completely sealed, so i dont really see a point to run a vent.....
i will have to see if i can get pics later
Old Sep 17, 2007 | 02:02 PM
estneon's Avatar
estneon
ok i know what your talking about cool less work
Old Sep 17, 2007 | 02:23 PM
12 volt's Avatar
12 volt
only other thing you have to worry about is corrosivesulfuric acid spitting in your trunk
Old Sep 17, 2007 | 02:26 PM
das2123's Avatar
das2123
ORIGINAL: mulletman11
yea once u start a car u dont even need a battery u can run off ur alt. connect ur bat cables an go!!haha
WHAT?
ORIGINAL: 12 volt
Thats why they make dry cell batteries!!!!
Old Sep 17, 2007 | 02:42 PM
Aerorat's Avatar
Aerorat
ORIGINAL: das2123
WHAT?
I know the older chvey's after the engine is running you can take the battery out just don't shut it off
Old Sep 17, 2007 | 02:45 PM
12 volt's Avatar
12 volt
most people still use conventinal lead acid.
Old Sep 17, 2007 | 10:15 PM
RiceBoy_88's Avatar
RiceBoy_88
How much is a dry cell battery? and where can you get them at? and is better to have your battery moved professionally or what?
Old Sep 17, 2007 | 11:23 PM
mulletman11's Avatar
mulletman11
ive definatly had te car jumped and taken the batery out, connected the cable and drove, as long as u can drve ok n dont stall or switch it off ur good
Old Sep 17, 2007 | 11:26 PM
das2123's Avatar
das2123
ORIGINAL: RiceBoy_88
http://www.odysseybatteries.com/
Only if you like wasting money. It isn't difficult at all.
Old Sep 17, 2007 | 11:36 PM
RiceBoy_88's Avatar
RiceBoy_88
ok thanks
