New motor??
Old Sep 24, 2007 | 04:14 PM
Jellysrus's Avatar
Jellysrus
Default New motor??
what do you guys think should i buy a new motor for my 98 or should i just rebuild the one that have the one that i have has blown head gasket and the rear main is leaking if i find one with low miles from a newer neon can i make the swap without swaping the computer if i get a sohc
Old Sep 24, 2007 | 06:10 PM
tattoojack's Avatar
tattoojack
Default RE: New motor??
depends on your tools, garage, experience. if i had enough of each i would rebuild it myself with stronger parts. otherwise, get a pro to just swap you into a used engine. safer.
Old Sep 24, 2007 | 09:58 PM
Aerorat's Avatar
Aerorat
Engine swap is not that bad unless you are doing the srt 4 swap and that just takes a little more time and thinking. ButI would try to stay as close to the same year as I could. As far as the pcm it depends on what cange overs you do like xtm to atm or sohc to a dohc.
Old Sep 24, 2007 | 11:12 PM
das2123's Avatar
das2123
Buy the Mopar HG kit from Modern and replace the RMS and be happy. I just purchased the kit and replaced my HG along with the timing belt, water pump and idler pulley myself.
Old Sep 25, 2007 | 08:53 AM
spudsterier's Avatar
spudsterier
why go through all the extra work to change the motor when you could just change a headgasket and rms and save alot of money????
Old Sep 25, 2007 | 11:35 AM
Jellysrus's Avatar
Jellysrus
well the motor has 155,000 miles on it and thought that if i could find one that had low miles i would be better off but i geuss i could just change the rm and head gasket and live
but if i got a say 2000 neon that was sohc and mtx like mine would i have to swap the pcm??
because if you dont and i can find one with about 60k and swap it in a weekend i would
Old Sep 25, 2007 | 11:39 AM
das2123's Avatar
das2123
ORIGINAL: Jellysrus
Nope, you would use the 1st gen PCM.
Old Sep 25, 2007 | 12:11 PM
protivakid's Avatar
protivakid
You could also consider swapping in a 2.4L from a stratus though if you had the sohc neon it'll require some dohc parts.
Old Sep 25, 2007 | 12:33 PM
Aerorat's Avatar
Aerorat
ORIGINAL: protivakid
if you are going to do a 2.4L swap you should go ahead and do the srt 4 swap
Old Sep 25, 2007 | 12:39 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Lol wow, this goes from a blown HG and leaky RMS to a SRT-4 swap, lmao
