trunk hard to pop.
what do i have to do to get the truck to pop easier. sometimes i have to have someone pull up on the spoiler while i pop it to get it to open. other times i have to use the key to pop it. but it does work sometimes if i really pull the trunk popper hard and fast several times. what kind of adjustments should i make.
while were on the trunksubject what have you all done to get rid of the rattle caused by subwoofers? i know its not the license plate but it sounds really bad from the outside of the car. what should i do?
I have the same problem with my trunk. What I did to fix it, was take off the cover of the trunk latch. It's just one metal line that goes from the latch, to the trunk. There's two screws that hold the rest of it in place. Unscrew them both and try to move the WHOLE latch piece towards the front of your car if you can, that causes the latch wire to tighten up. That's the reason why your trunk doesn't pop open is because that wire is most likely stretched a little. If you can get it tighter, it'll pop better. And to answer your question about the trunk rattle, there's two things you can do. 1. Use black tape, just a small amount like 2 inches, and wrap it around the metal clip your trunk latches to. When you latch your trunk, itll sit tighter to the metal ring it latches to, and causes the trunk to rattle much less. 2. Buy some Dynamat and spray it all over the panels of your trunk. They use Dynamat on truck beds to make them tougher, and it sort of sound proofs your trunk.
my trunk is dynomatted and it still rattles like a biatch
i wouldnt waste your money on it.. but it might rattle less.. idk ive never heard it without the Dynomat but my trunk does rattle alot so im gonna try the black tape thing even thought it sounds retarted but if it works it works
Trending Topics
