first gen srt-4 turbo tuning PLS HELP!!!!
Old Oct 23, 2007 | 10:41 PM
noenwarrior's Avatar
noenwarrior
Default RE: first gen srt-4 turbo tuning PLS HELP!!!!
well i dont have money to get one right now what can I do to make this work anything i can make to raise it up maybe??? or can I make one i seen something bout getting a part from radio shack anybody know anything about that?
Old Oct 23, 2007 | 11:12 PM
spudsterier's Avatar
spudsterier
unless you get a map clamp or make one then there is nothing you can do to safetly drive the car
Old Oct 23, 2007 | 11:15 PM
noenwarrior
anyone know how to make a mapclamp?
Old Nov 29, 2007 | 02:57 PM
99neon2.4's Avatar
99neon2.4
where is the turbo checklist at
Old Nov 29, 2007 | 03:43 PM
mmench's Avatar
mmench
i read somewere ( i dont remember were ) that the voltage output of our map sensors should be clamped at 5v? it was somethiing like a reading of 20lbs of vacume was like .5 volts and a reading of 0 vacume put out 5v or something and if it went into the boost side it would register more volts. when it sends more than 5v to the comp it freaks it out and leans the fuel to correct a problem.. so its like the map clamp keeps the computer from receiving more than 5v .... dont hold me to it but thats just what i read somewere .... and im not sure of the real voltage numbers or watever.
Old Nov 29, 2007 | 05:00 PM
spudsterier
ORIGINAL: 99neon2.4
https://dodgeforum.com/m_602815/tm.htm
