White, milky subsatance in oil???
Old 11-08-2007, 07:10 PM
neoncrazy101's Avatar
neoncrazy101
neoncrazy101 is offline
Default RE: White, milky subsatance in oil???
when we first got our '90 Legacy, the coolant res. had a white milky sustaince in it. it ended up just being the type of coolant that was used in it before. isn't the chocolate milk color what you have to worry about? have you tried changing the oil and then seeing if it comes back? and are you loosing coolant or is it just over heating?
Old 11-08-2007, 07:24 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Sixtysixdeuce is offline
I have the MLS gasket. You still think it's breached?
Well, if you've been loosing coolant and can't find the leak, then it's been going out of your tailpipe. It probably just finally got bad enough to breach into the oil.
Straight water takes a lot longer to mix with oil than antifreeze. It'll show up as gooeycondensation at the top of the engine first (in the valve cover and on the bottom of the oil cap. Soon there will be enough that it'll show up on the dipstick above the oil. In time, it will permiate the oil and go "chocolate milk".
Old 11-08-2007, 07:45 PM
wallacereid's Avatar
wallacereid
wallacereid is offline
Rats, that's exactly what's happening...it's even starting to find its way into the throttle body via that recirculate hose. I'm screwed...
Old 11-08-2007, 08:11 PM
Slashwannabe's Avatar
Slashwannabe
Slashwannabe is offline
ORIGINAL: Sixtysixdeuce
What is Loosing? You mean losing? Losing and Loose are two different things! Sorry to sound mean but I'm not trying to.
Old 11-08-2007, 08:28 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
ORIGINAL: wallacereid
My TPS (throttle position sensor) light came on
you have a light for you TPS????
Old 11-08-2007, 11:22 PM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
you must hate when people do that slash thats all you talk about
but if i were you i would believe its the head gasket, your talking to neon pros (not me)
Old 11-09-2007, 12:22 PM
Sixtysixdeuce
Read through my other posts. I type fast and often post without proofreading first. I'll only go in and edit for gross errors that truly affect the way it may be percieved. You and everyone else knew exactly what I meant, despite hitting the"o" keyone too many times.
I screw up if, to, the, and, etc all the time. Fi, ot, hte, teh, adn, nad, and so on. Message board, not turn paper.
Old 11-09-2007, 01:35 PM
hnda8r's Avatar
hnda8r
hnda8r is offline
You mean TERM PAPER...lol [sm=icon_beat.gif]
Old 11-09-2007, 04:23 PM
das2123's Avatar
das2123
das2123 is offline
More than likely you have a blown HG. Might as well change the timing belt, idler pulley and water pump while you are at it
Old 11-10-2007, 12:09 AM
Sixtysixdeuce
OK, that one was egregious. Happens late in the evening when I've been at it for a few hours.[sm=insomnia.gif]
Quick Reply: White, milky subsatance in oil???
