White, milky subsatance in oil???
11-08-2007, 02:34 PM
on
I have a white, milky substance in my oil. It seems to be flooating on the top, and is clearly seperated from the oil. What is it?
11-08-2007, 02:35 PM
on
RE: White, milky subsatance in oil???
water?
11-08-2007, 02:40 PM
on
No, not water, it seems to be about the same consistency, looks like what two different color paints might look like when first mixed, you know, like little swirls. My car has been overheating. Any idea?
11-08-2007, 02:42 PM
on
head gasket popped. Coolant is mixing with the oil.
Edit: I almost didn't mention as you already know this is bad, but don't drive it. It doesn't take long for coolant to eat the crank and rod bearings.
11-08-2007, 02:43 PM
on
thats wat i was thinkin. any loss in power or change in power?
11-08-2007, 02:44 PM
on
Sure??? I have zero anti freeze right now, since I has the cooling problem. 100% water. Still the Head Gasket?
11-08-2007, 02:46 PM
on
My TPS (throttle position sensor) light came on, but I think that's just because I'm running hot and melted some insulation on the wire.
11-08-2007, 03:24 PM
on
Sorry to say this but its a blown headgasket. And like they said DONT DRIVE IT ANYMORE
Do you happen to have a MLS gasket? if not you'd better get one. lol[&:]
11-08-2007, 05:03 PM
on
Yes, this is a 1999 model with the MLS gasket, that's why I did'nt expect this to be the issue.
11-08-2007, 05:06 PM
on
I have the MLS gasket. You still think it's breached?
