HELP! Installing White gauges. I cant drive like this!
today i was trying to instal some white face gauges. I took out the needles, plugged them backed in, etc. However, when i turned the car on, the gauges are not working anymore! My speedo stay at 0, the Heat gauge stays where it is and my gas doesnt change! Can someone please help me! when i turn off the car the gauges stay the same. How can i fix is this issue. i cant drive like this. Btw, i put the after market face gauge on top of the original face gauge because of those tiny point the needle sit on. this is what i bought. eBay Motors: i260 95-99 DODGE NEON WHITE FACE RACING GLOW GAUGES (item 3001707
Your problem could be simply that the needles are getting caught on the new white face due to clearance issues. Happened to me. I solved it by applying a little water soluble elmer's glue on the back of the white faces around the needles and held it down firmly a couple minutes while drying. The other problem could be that you took your needles off to install the white dash. I have heard from a couple people to not take the needles off or you can run into major problems. I installed mine by slipping it under the needles without removing them.
the problem with mine was the needles getting hung up.....the overlay needs to be completely flat without any ripples or anything.....also remember, you get what you paid for.....
ok here is what i did. I put the new white face gauge on top of the old one because the new one Does Not have any have pictures for the signals (seatbelt, lef + right turn signals, etc)..i think i f**d up. so by putting the new on top, the signals would show. ahkkk.. i should have left it the way it was
ORIGINAL: spudsterier
chances are like I said its the needles getting caught which elmer's blue fixed. Double sided sticky tape would only add to the problem as it has that little bit of depth to it. And I left my old black face on, its just an overlay, you don't take the black face off.
Trending Topics
Mine works just fine with double sidded sticky tape (dsst). I had the same problem. I took the needles off and the needle stops put dsstall over the original face carfully put the new white face on and then put the needle stops threw the new holes to lock them in and then put the needles back on.
they all do that. they go over your stock guages so the lights will show thru where needed. thats the design. all you gotta do is stick it down flat, and be careful when tightening down the clear shield because this can cause it to ripple. also if they came with directions, you will notice it says not to remove the needles. they will slip over them with a lil effort and positioning.
just installed mine today/night. hah well i didnt use double sided stickey tape or glue. Its called single sided sticky tape! heh. You just use the single sided to tape down the edges real flat and that i used the singled sided again right next to the gauge holes just very carefully just on the outside. The trick with taking the needles off is....start your car up without needles and than when its fully warmed up you put the needles in accordingly. Temp gauge at its regular warmed up temp. Gas gauge at the spot where your gas is (should mark it down be4 taking needles out/installing back in. Speedo at 0 and your idle at roughly 900 just below 1000
but thats just what i did and it worked for me
** Just a quick question** i havent done the wiring yet (as its dark out) so it glows blue or w/e it does. Do i just do some wiring splicing with the red wire to red wire and the black to black?
but thats just what i did and it worked for me** Just a quick question** i havent done the wiring yet (as its dark out) so it glows blue or w/e it does. Do i just do some wiring splicing with the red wire to red wire and the black to black?
