I put a head from an '03 SOHC on a '95 SOHC without a problem. I had to drill and tap for the EGR valve and switch the cam magnet and sensor. Everything was basically change and go. I've put 15,000 miles on it so far; no problems whatsoever. hope this helps.
what your going to be looking for is a 00 or a 01 dodge neon R/T. if you can get the intake manifold with it get it...best intake you can get for a neon PERIOD. it even outflows the indy
ok the best STOCK intake manifold. It has a second set of runners for each intake port and a relay opens the second runners up after a certain rpms giving you more air where you need it in your powerband, (kinda like vtech but not. vtech opens a thrid valve in the head, R/T manifold opens a second runner for each intake port.)...if you were to get one from mike it would outflow the 2nd gen R/T manifold. the magnum head you have to remember is a SOHC but ithas a hotter cam then a stock SOHC and better springs also has bigger intake and exuast ports. dont know if it also out performs the stock 1st gen dohc or not...Mike would be the one to answer that.
